I find pounding 2 nails through a piece of wood works better than needle nose pliers and cheap and easy to make. You just have to get the nails in the wood reasonably close to whatās needed and then bend them to fit in the notches.
Please take a look at THIS suggestion. The variant I use myself is a combination of a 2 inch SS nail and a small round pry bar (the handle of which can rest in the palm of my hand). The way you cross them depends on what you want to do (loosen or fasten retaining ring). The rubber band is not meant to apply force but to prevent things from flying around.
Got mine about a week ago. It worked pretty good for a few hours then became erratic, then wouldnāt turn on. Threads cleaned and metal particles blown out (just a few shards). Came here to BLF and performed recommended tweaks: caps and temp sensor calibrate. The flashlight is working fine now save for muggle mode, which is somewhat unpredictable. Most of the time mm works, but sometimes it ramps down from hi. Temp was reset a couple times with no change to mm function. I placed the flashlight into the refrigerator, curious to know if the thermometer in the FW3A was working. It works fine. All other functions besides mm work as designed. Since I donāt loan out nice flashlights, muggle isnāt that important to me.
I have to say, this I the nicest looking flashlight I have ever seen. The gray matte anodizing is sharp looking, and the design is what I would call understated class. Reminds me of the old e-type jag before rubber bumpers. The tail switch is quite satisfying, aircraft grade all the way. There is not one thing I would change about the programming. It is a logical and intelligent UI, though it took me awhile to figure out. Turbo, oh christ, itās a firebreather. Amazing. Moon is nicely dim, just right. If lens is turned skew to strong light it exhibits tones of pink and purple, indicating a good anti-reflection coating.
The transition from spot to spill is almost seamless and the beam shows virtually no color shift or artifacts. Very nice. I have the 3a. I donāt know the cri but it must be pretty good. The pocket clip looks to me like dark gunmetal, not black, and is plenty strong. I left it attached so it wonāt roll. I would like to see what a matte finish natural titanium clip would look like.
My compliments to the FW3A team for putting together a solid contender in a really crowded field. My compliments to Lumintop for bringing it to life with a quality build. The FW3A is a real thoroughbred, and a pleasure to use.
Theyāre actually not very good for the FW3A if the driver retaining ring is super tight like on my one, tried them, failed.
Might work to get some tightening done but better to use a set of old small flat tipped tweezers with the tips bent outwards.
It seems like we all missed your posts for some reason. :person_facepalming:
Make sure your not in muggle mode and then report back what itās doing. Maybe copy and paste if itās doing what it did before. Iām still not sure what your describing. Are you trying to change the rate of the strobe?
Iām running into the exact same problem, one head not receiving power. Is yours a 7A tint by any chance?
Curious to know if a multimeter between your (-) wire on the MCPCB and head threads shows any resistance. Mine looks like an open circuit, and makes me think the driver solder joint has failed.
Iām not quite sure how to take apart the FW3A. I am able to take off the lens of the head. If thatās what you mean. It does look like the negative wire isnāt attached anymore.
I have the 3D version. I donāt have access to a multimeter, Iād have to go buy one at the moment. I donāt have any experience with electronics and soldering. I took off the lens and optic, it does look like my negative wire isnāt attached to the board.
Iām not quite sure how I can post pictures on here, but hereās pictures of a comparison of the two heads.
Yes, that would definitely make it not work. Iāve now seen two like that.
I canāt quite tell from the picture if the solder came off the pad, or if the pad came off the PCB. In the former case, it should be easy to fix with a soldering iron. In the latter case, you probably need a new PCB. But in any case, this would probably be a good time to ask Neal for a replacement.
Looks like the old twist & break.
There is no real play in the wires with the FW3A so when screwing the head on you need to make sure the optic/ MCPCB stays put and doesnāt rotate with the part youāre screwing on.
The one on the left looks like mine when it was on turbo for a few seconds & started to smoke then stoped working , then I looked at it I noticed the wire was off.
It would be good if it were just that , I havenāt bothered soldering it back on because only two leds are working properly ,so Iām waiting on Neal to see if he can send me a new head.
Huh. For me that would be a valued optional feature, please post if you find thereās a way to set that up.
Not that it should always do that, but for pedestrian safety in crosswalks I do that āstrobe on ā¦ stun oncoming drivers ā¦. scuttle across the street ā¦. strobe off ā¦.ā a lot.
Thatās the default. It remembers which strobe was used last, so a āclick, click, holdā from off goes back to whichever strobe-group mode you left it in.
For street-crossing purposes, the bike flasher is probably appropriateā¦ and it can be accessed from off within about a second if it was the last strobe-group mode used.
