Reserved for Lighted tail switch mod.
Good work
The almost non increase when lowering the sense resistor indicates you are running the regulator way outside safe operation levels and more like DD the thing
Yelp, and all 16340’s have to much voltage sag to matter.
Now that I have had a few months to play around with this modded light, everything seems to be working fine even with a Olight 16340 10C battery. The best lows of any light I have and a decent beam with a LH351D 4000k 90 cri using the stock reflector.
Jon_slider had problems with the lumens fluctuating when he rotated the light as seen here. Sunwayman V11R on Ebay, $18.99. 2 left. - #270 by jon_slider
With all 3 modded V11R’s I have, none experience this issue when rotated in my lumen tube. I don’t see more than a 7 lumen difference on high while rotating the light 360 degrees and this could mostly be the slight change in angle when trying to hold the light straight up and down while rotating. In my lumen tube if the light is tilted just slightly down towards the tube path the lumens reads slightly higher, just a few lumens. So none of my modded lights appear to experience this issue.
Very helpful instructions and pictures!
I have receintly acquired a Sunwayman V10r Ti and replaced the LED with my prefered Nichia 219b sw45.
I, of course, neglected to measure the drawn amps before the LED replacement, but with the 219b the light draws 1.82A at when it turns on.
It gets warm soon and hot after a couple of minutes. I feel it could go up to 2.2A safely, but the thermal properties of the light, especially being Ti, do not seem good enough to dissipate the heat from more current going through the not-very-efficient 219b.
moderator007, do you remember the Amps on the unmodded light? I have ordered the BOM you are suggesting, with different capacitors, as the ones you are linking are not available (The only difference is the capacitors you were listing had 20% tolerance and I got ones with 10%). I also have some 0.1ohm and some 0.082ohm resistors rated to 1w. Would 1w be enough or would I still need to solder two in paralel? I do not want to go too low on the resistor, as I do not want to exceed 2.2A.
I am a bit comprehensive as I do not know if I will be able to find a replacement circuit board if the original gets damaged beyond my ability to repair.
My V10R untouched everything factory light draws 2 amps from a vapcell 16340. From a fenix ARB-L16 it only draws 1.4 amps. So what battery you use will change the output since it’s basically direct drive with the voltage over the vf of the led. The vapcell 16340 is the best high drain battery in it’s size that I have tested.
If using the 0805 resistor I would use a stack but at 2.2 amps it might be alright since mine factory is drawing 2 amps with the vapcell. Moving up to 1206 1 watt should work great since the light came with a 0805 with a 1/2 watt or less resistor.
Try the .100 ohm resistor first and see what it draws. The current draw isn’t the same as the current to the led even though it’s direct drive. You still have all the other components resistance in the path. Changing to better lower resistance components allows the led to see more current. You also have to take into consideration that the output drops as you use it as the battery voltage drops. The better the battery the higher sustained output you’ll have as it falls. Once it goes below the vf of the led the PAM2803 takes over and the better components will give you a slight increase in output as well from being more efficient. With mine, I don’t use it on high that much at all, but it’s there if I need it.
If you use the larger diode the side of the diode near the inductor can be filed a little to give a little more clearance.
Thanks for all this information!
I have some 16340 vapcells in the mail, but not at hand yet. I was told they are not protected. Does the driver offer LVP or do we just need to be careful?
I am going to use 1206 1W resistors, so I will go with one. That should eliminate the touching the anuminum cap issue.
I am thinking of replacing the other parts with the lower resistance ones, and then regulate by selecting the correct resistor, for my taste in Amps. Isn’t that what you are implying would be the best way?
Exactly, it makes the driver more efficient either way and should be more reliable with the higher rated components… Less resistance, less loss in the components and more current to the led.
Nice
I was wondering if you might be able to help me. I posted this (below) elsewhere and was directed to you here and it looks like you may know the answer to my problem. I am guessing that my problem may be the 4.7uH inductor. Does it sound like it is just that or might it also be the component (in your first picture) at the bottom with the glob on it because on mine that looks like it is also an inductor and it may be damaged because I can see windings exposed and there looks like the top of it may have a small piece broken off.
Sunwayman V11R repair?
I have contacted Sunwayman already about this, I filled out a contact form and I am waiting for them (in China) to reply.
I have had a V11R for a few years and really like it but just the other night it stopped working and it appears to be the V10R V1.4 control board inside the flashlight, the parts on that board that react to the variable intensity ring being moved seem to have disintegrated. There were parts floating around in that part of the flashlight. They appeared to be magnetic. I was wondering if is it possible to get a schematic and parts list so I can try and find the broken parts and replace them myself. There are 2 devices on the board that look like electro magnets and they seem to be physically broken. I assume that they interact with the magnetic ring to change the intensity of the light.
I am sure that I have dropped this light a few times but the latest drop seemed to break those little parts inside the light. I have a used one on its way to me now but I would like to fix this one since I think it is something that will break again.
I just now saw your post. Sorry I didn’t get back here sooner.
I’ll try to help if I can, I think I understand the output side of the driver but all the components for controlling the rotary position sensor I never tried to figure out because it only controls the amount of output in relation to the magnets positioning to the 316BCG, not the peak output.
The second smaller coil on the bottom in the my first pic, I think is just part of a boost circuit to supply enough voltage to the 316BCG. The 316BCG from the datasheet requires 4.5v min to operate. If it’s bad then there will be no light. I replaced one that had that same problem.
There are two magnets glued in the control ring that move with the control ring that changes in position in relation to the north and south axis of the 316BCG. As they move the 316BCG pics that movement up and relays the position to a mcu which in turn outputs so much current according to that position, which I think is programmed in the mcu firmware. The jetbeam rotary lights seem to have the same circuit but offer a strobe mode and sos with a double turn to high and a triple turn to high for sos. Pretty sure thats just being picked up in firmware just like a double tap for high in Narsil with a e-switch.
I would check the two magnets in the control ring and the small coil if you think it’s not connected. If you can reconnect it even if you can just solder the winding wire to the pads to see if it will work might help. Then you could find a replacement coil and reflow the new one on.
The magnets also have a north and south, if you get them out of sink or in the wrong way the position sensor will not work correctly. Takes a little experimenting to figure out which way they go. There tiny too, so be careful where you open the light up and try not to lose them.
Just shoot me a PM if you need any further help.
Great post! Was thinking about to get one V10R…
The V10R has been discontinued for some time now. You can find them used every now and then on ebay or here on the forum.
The V11R can still be found in a few places. Sunwayman V11R CREE XM-L2 U2 Variable Output 1 x CR123 / 1 x AA 500 Lu?
Sweeeeet!
Thx Mod!
Capacitors C2012×7R0J106M125AB https://www.arrow.com/en/products/c2012×7r0j106m125ab/tdk
Looks like not avail at arrow anymore. What would be next one in their offering? I’m a huge noob in electronics…
You may order Samsung CL21B106KOQNNNE at Arrow instead.
You would need only one of these 22uf instead of using two 10uf paralleled, just swap the original out. Should work just as good, two paralleled that microa recommended will work also.
https://www.arrow.com/en/products/c2012x5r1a226k125ab/tdk
Thx guys! Cart has been updated.
Gotta question regarding V11R’s…they are XML reflector lights, so how is the beam with XPG size emitters? What’s the size of the MCPCB?
Just to know what to expect when i get “11”
The bean looks to me decent with the LH351D 3535 emitter.
The MCPCB size is 12mm. This is the only place that I found at the time that had them. https://ogazent.com/store/leds/xp-g2-led-on-12mm-copper-star/
Relow the xp-g2 off and use the 3535 emitter of your choice. The xp-g2 1A would be a little to much on the cool side for me 6500k.
