I made my first video of the production version of MS18. I speak in hungarian but it has full english subtitles.
Hope you will like it. I teared it to multiple parts. Don’t want to make it too long. This part 1 contains unboxing, first thoughts, user interface, how it works and some teaser blinks of what is next.
ZozzV6, really nice video review you have created.
Ya, strange that 10k doesn’t have active cooling feature, maybe Imalent set the temperature threshold quite high to preserve battery.
Thank you!
No. User manual said that only the 22000 lumens or above levels have the fans automatic activation. They told me they could hold in hand after 20 minutes in 10K lm. Maybe they less sensitive to heat than me I will try to measure heating up in 5K and all above levels and monitoring temperature but I will stop if it reach 70°C on the head.
Brainsick67, thanks for the review. Now I know that two pieces are plastic. Good thing is that it will be lighter.
I personally think Acebeam has given up to compete with Imalent this round. They don’t release any info about their future beast to hold on their potential customers who want to buy big flashlights. Looks like their plan is to watch Imalent release MS18 and see how it goes.
Then it is quite sure they really design active cooling for lumens higher than 10k only. Their thinking might be that DX80 has no fan and it is 30k lumens.
But I think if there is a active cooling feature, why not have it for all modes, let the temperature decide. If user uses Turbo and 25k for let’s say 5 minutes, and then switch to 10k lumens, MS18 should still be very hot.
I have ordered a R90TS,but my order is in the processing status till 24/05, because they try to fix a problem with the plastic case which is in the box.I think they start again shipping at 06/06.
You can’t manually turn on fans at any level. Just when flashlight is off. That is sadly limits the use of the 10K level. It is better to use 22k if you don’t mind the fan sound vecause the light is cooler in that level than 10k. At 22k I measured 50°C at head after 10 minutes.
