Display PD power-data objects (PDOs) in the Protocol Detect function of the TC66C. You show the supported voltages already for QC and it would be great to see the information for PD.
It looks like you are already detecting them since Protocol Trigger shows only the supported voltages.
I have an idea for a product, but not for this particular tester.
Since you already have a number of devices that can measure and log current and voltage simultaneously, I’d love one that could be connected to a standard 18650 or AA cell in a charger to measure the performance of the charger. Right now, the cheapest way to do these tests is to buy two logging DMMs and use a custom piece of software to record from both at once, plus you need to make some modifications to ensure the added resistance isn’t too high.
Speaking of ideas for new products, a Li-Ion battery discharging/analyzing rig would also be useful. Most of the regular analyzing chargers only discharge at 0.5A or so.
[Excellent tester, comes in the case. Control occurs with 4 buttons. On both sides of the type-c socket, there is also a microusb input. Automatic qc protocol testing menu Long press the right button input to the menu. Left button input under menu It is possible to connect the tc66 tester to the computer. To connect, you will need a microusb cable. Well, the most interesting, you can download the program to your phone, and connect via bluetooth. The tester is excellent, i advise!]
product link:[Click Here]
another review(Thank you for your support)
[Technology with a type-c connector becomes more and more, so this tester was so necessary for me) with it i can check the capacity of the charge of the superbanks, track the characteristics of the charge technology and output via bluetooth all this on the phone screen, check the wires for conductivity and evaluate the charge protocols. I like the product the ability to trigger quick charging protocols: it is immediately visible that it supports charging and where the sagging occurs. The tester is miniature, which is convenient. The small screen displays many functions of charge, characteristics of current, voltage and capacity. Purchase is satisfied! I advise the seller. Delivery took 9 days. The tester is suitable for everyone who wants to be aware of the quality of the cords used and, most importantly, check the supported protocols in the adapters for lice.]
new review(from Japan)
“Meanwhile, RD TC66C of the new product also supports measurement of USB PD 100W at a low price of $ 24.50, and also supports trigger functions such as USB PD, Quick Charge, and FCP. In addition, it is possible to connect to a USB cable and see the current and voltage with a PC, as well as to confirm with a Bluetooth connection and a smartphone application.”
quoted from “”click here”“:RD TC66Cレビュー。USB Type-Cポートに直接挿せるPD 100W対応万能テスター - AndroPlus
product link: https://www.aliexpress.com/item/32968303350.html
