That picture was made by me
My wife was cooking a lot in winter and everything closed in the house. I made this picture very close to the kitchen
For centering rings in C8 I usually sand down the gaskets. It is not true they are self centering themselves on a white flat led. If the MCPCB is not in perfect center it will be no good. Also reflector can move sideways a little while tightening down. I used to shine to the ceiling while tightening the bezel last few turns and smack a little the side of the head and every time I just tightening a little and then smack again if the spot is not perfect.
KW CULNM1.TG is 4.0x4.0mm version of KW CSLNM1.TG (or 1mm2 version of Oslon boost HX), with lower thermal resistance, I tested two 5Q bin samples under same conditions (fan cooled heatsink), results:
So we got the first white LED that broke 1000lm/mm2 barrier (by a decent margin in case of higher performing sample)
What can be seen from numbers is two samples are within 5Q bin rating (710 - 800lm@3A), but one is at bottom and other is closer to upper level. 5Q bin is comparable to 6N bin of CSLNM1.TG (315-355lm at 1A).
Compared to CSLNM1.TG (white flat) peak current is just a litlle bit higher 6.0-6.5A vs ~5.75A. I was surprised by this, I expected more like 7A, but it seems droop effect at these current densities becomes so dominant that output stops increasing even if you cool LED die well.
But CULNM1.TG's lower thermal resistance does help and max. output is higher at high currents.
Also the other good thing about lower thermal resistance is lower junction temperature, at 6Amps die temperature is about 75C higher than ambient, CSLNM1.TG temperature at 6Amps would be ~96C higher than ambient. So CULNM1.TG should be more reliable /longer living at high currents.
Disadvantage is considerably higher price compared to CSLNM1.TG and the fact that it has been already "scheduled for obsolescence " by OSRAM due to lower than expected demand.
I know we can’t fix that with our paltry numbers, compared to corporate purchasers. But it would be nice if we could help it a little with a group buy or something.
What is the price for these? Can they go cheaper because of otherwise low demand?
PS: Remember too, that the L4P Q8 replacement MCPCB has 4040 pads on it.
A little less than I expected….but nevertheless HAIL TO THE NEW KING.
It makes 336 cd/mm², twice as much as XP-L HI (which needs > 4.2V to reach its max). And it’s better than Black Flat by a third.
L4P could you share the datasheet?
ADDED: BTW, according to my notes Enderman got 1115 lm out of White Flat. Though I guess this is more of a test setup difference, I strongly suspect that your lumens are different than his lumens.
Boost HX is just CSPM1.TG in 4040 package, so you can expect similar difference - 5~10%, I don't know why people are hyping boost HX so much, like it's gonna perform 50% better than CSLPM1, it's the same die in bigger package.
According to the datasheet it offers the same lm/A with lower Vf - so it’s more efficient. And thermal resistance drop is huge, to the point that K/W/mm² is better than that of White Flat.
Considering that thermals used to be the most important performance predictor for overdriven LEDs - yes, Boost HX looked revolutionary.
Your Boost HL results do curb my enthusiasm. Though I still expect it to be the best LED for large throwers.
Hmm, exciting times for my Z1. Maybe I'll throw this in it. I'd been planning on reflowing a white flat from 16mm to 20mm board, since I damaged the one on my 20mm board.
Sample 1 of CULNM1.TG is clearly less efficient than White Flat but it holds up longer to achieve ultimate win.
Sample 2 is slightly more efficient and keeps its own early on while pulling farther ahead at high currents.
Nothing surprising.
BTW, sample 1 didn’t reach 1000 lm/mm². The die is 1.069 mm² so it’s a tad under 960 lm/mm². Sample 2 exceeded 1048 lm/mm².
Yes, HX is more efficient than CULNM1.TG - reason is 2x larger die, so you need 2x lumens for the same throw. I agree HX would be better for bigger lights, but for small and medium lights CULNM1.TG/CSLNM1.TG is better for maximum throw at still relatively low current of ~5-6Amp.
No, Boost HX was supposed to be more efficient than CSLPM1.TG. See the datasheets. Both have about the same output at any given current, from 1A all the way to 6A, both with the lowest and the highest bins.
But Boost HX has ~2.89V at 1A and White 2 has ~2.94V. Small but grows with current. At 4A it’s ~3.2 vs. ~3.29. At 6A ~3.35 vs ~3.52. That’s where the datasheet ends, about 5% difference. If the trend continues this should be about 7% efficiency boost at high current. And considering that peak output for all new Osrams is just below 50 lm/W - this lower Vf should push the peak intensity up by about 7%.
Actually even if the Vf difference is not there - it should still gain more from the bigger package than the 1 mm² die. Because it was more thermally limited at 3030 format in the first place.
I expected Boost HX to seriously undermine the XHP35 thrower market. Now….I still think it will make a splash. Just not that big one.
Datasheet Vf curves are usually given for some typ. Vf bin, what I see in real life is CSLNM1 and CSLPM1 come in lowest "15" Vf bin, while CULNM1 (my samples) are middle "B5" Vf bin.
This means you can't really make predictions using datasheet numbers, Vf values of "15" binned CSLPM1 are considerably lower that what datasheet suggests.
Another picture, rescaled each curve so they start at the same point.
This way we can see clearer how does performance scale with current, abstracting away efficiency of individual LEDs. Here some samples are clearly better than the others, such test hides this difference.
The curves for Boost HL nearly merge into one, that’s good…much better than I’d expect…this hints at very good test setup.
I would expect Boost HL and White Flat to score pretty much the same at low currents but pull ahead later on.
That’s not the case, they start the same, White Flat is actually better at middle currents and Boost HL pulls since 4A (which is about 6.5 at the X axis).
I would think this win in the middle to be a test fluke but the consistency of Boost HLs makes me wonder it’s actually real.
I don’t know and I don’t have an explanation.
Which numbers did you use for cslnm1.tg? You have mentioned Enderman got 1115 lm, I got considerably lower max. (950~980lm) for the same 6N bin, djozz' numbers seem to be also <1000lm from last test.
Also it's worth mentioning that 6N bin is second highest datasheet bin fom cslnm1.tg, while 5Q bin is second lowest datasheet bin for culnm1.tg.
We don't know what bins are practically possible, but we can realistically assume culnm1.tg could come in one bin above 5Q.
