Hi, BLF member
ANEKIM is the first to introduce a VC30 (P9) flashlight. You are welcome to test our product reviews.
The first 10 samples, we will send é to DHL quickly.
For new products, we will have a 20% discount (2088RFWR). For details, please click the link below.
https://www.amazon.com/gp/mpc/A1QCJSZZLDF05C
The purpose of opening this theme is to find reviewers and any comments you have about this flashlight.
Features:
· OSRAM P9 LED, maximum output 1050 lumens, strong concentrating performance
·Tail magnetic design, head and tail double spring design, shockproof, anti-drop, anti-attack, easy to use.
· Full-featured: Click very bright, double-click flash, stepless dimming, low voltage warning, USB portable charging, intelligent temperature control.
· Convenient and easy to use Micro USB charging port design, charging current up to 1A, charging faster. The charging port increases the protective cover, effectively dustproof.
· Anti-reverse design to prevent battery damage against circuit and LED.
·Air-grade aluminum alloy material, military grade oxidation treatment, wear-resistant and scratch-resistant more sturdy.
·Integrated barrel design for more efficient heat dissipation
specification:
·Model: VC30 (P9)
·Working voltage: 2.65V - 4.2V
·Compatible battery: 1x18650 rechargeable battery
· Beam distance: 245M
· Peak beam intensity: 10008cd
·Reflecting cup: smooth cup
·Switch type: side push switch
· Size: 126mm (length) x 25mm (tube diameter) x 25.5mm (head diameter)
· Weight: 96 grams (without battery)
·Material: Aviation grade aluminum alloy, military grade oxidation treatment.
· Waterproof: IPX8,
·Lens: tempered glass, scratch resistant
·Accessories: USB charging cable, O-ring x2, hand strap x1, holding clip
