SALE: Low-cost copper pills, spacers, optics, drop-ins.
1849 posts / 0 new
kiriba-ru
kiriba-ru's picture
Last seen: 12 hours 44 min ago
No abilities to produce them right way.
Asian8640
Asian8640's picture
Last seen: 11 hours 48 min ago
WTF wrote:
Asian8640 wrote:
Hi! Do you have any spacers for the Convoy M2 for a quad?
I would like one as well, prefer aluminum if given the choice.
I would like aluminium as well. My intended build won’t be high output and I don’t want to have to worry about galvanic corrosion between copper and aluminium.
Old Lumens Contest Entries: "7th 5mm LED Lantern":https://budgetlightforum.com/node/70438 and "9th Copper Pipe Triple":https://budgetlightforum.com/node/79484
Scallywag
Scallywag's picture
Last seen: 46 min 39 sec ago
My order arrived nice and safe over the weekend. It gets installed today, but I already opened it and the retaining ring threads into the pill like butter.
If anyone's wondering, it was packaged nicely and took 20 days to reach the continental US, with tracked shipping. As expected, and I'm quite pleased.
kiriba-ru
kiriba-ru's picture
Mag D sets are sold out, but I still have 3 empty drop-ins.
kiriba-ru wrote:
Still have few empty (no pill inside) Mag D drop-ins. If anyone interested, I could try to make some bigger pill for different application (probably multi-led).
If nobody is interested in custom pill for bigger pcb or custom optics or etc., I will make same 16mm pills as were provided with my sets and sell them as is.
VaKo
Last seen: 3 weeks 3 days ago
Would it be possible for you to make this spacer for the Convoy S11 host in copper?
It was designed by a Reddit user named DE-173 in this post. and they were kind enough to share their design for the spacer.
kiriba-ru
kiriba-ru's picture
I have host on hands and can do a sample if you need.
VaKo
Lets make it happen Smile
kiriba-ru
kiriba-ru's picture
Is there any need for M2 quad spacers if I will make S11 full height quad pills?
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 2 hours 14 min ago
Better wait for S21A.
kiriba-ru
kiriba-ru's picture
S21A should fit triple optics, not quad.
S11 is great out from the box. If you want custom leds and driver, youd probably move from ugly XHP tint to 4 smaller but more pretty leds. So you need spacer. If I went with my regular quad design (Cu spacer+brass liner ring), this would cause too many parts that have to be put under stock pill (also youd probably use 17mm driver so extra adapter was necessary). I think full height aluminium quad pill with 17mm driver place is good consensus, not so heavy, not so expensive, not tricky for build, better thermal transfert, no need in extra adapters. Also full height pill design is easy both for upgrade and downgrade – this is not common for S2+ (smaller size+similar drivers) but should be cool feature of S11. Just have two sets – stock pill with reflector and quad pill with optics. And change between them when you need.
Tally-ho
Tally-ho's picture
I’m in need for a 18650 quad host and was wondering if the Sofirn SF36 would not make a better host than the Convoy M2 since the SF36 with XP-L HD is regularly on sale with a reduction, actually US $16.95.
If not, I will go for the M2 spacer, 3 or 4 units (in aluminum).
kiriba-ru
kiriba-ru's picture
One M2 kit (copper spacer) available.
I have build SF36 quad once. But sofirn is not convoy, they used to change flashlight dimensions occasionally. I need to find my drawings and measurement and compare them with hosts that are sold nowadays. Hope some thread subscribers could help with measurements.
VaKo
90g of copper spacer for a quad S11 build I’m piecing together:
kiriba-ru
kiriba-ru's picture
Still have some C8TT heads. For those who are not satisfied with 3 led version, I can mod them to accomodate 40mm anna-6(7) optics:
2019-01-31-21-31-08
contactcr
Last seen: 1 day 10 min ago
Now this is tempting but I’m out of my C8 hosts. Hmmm
kiriba-ru
kiriba-ru's picture
And yes, I still think that full head design is usefull feauture because you can swap heads.
Skylight
Skylight's picture
Last seen: 22 hours 19 min ago
What would it add the the cost of the C8TT?
kiriba-ru
kiriba-ru's picture
$5.
contactcr
I assume it can’t be re-threaded for the 21700 C8, right?
kiriba-ru
kiriba-ru's picture
Right.
Caleb
Caleb's picture
Last seen: 22 hours 44 min ago
kiriba-ru wrote:
Still have some C8TT heads. For those who are not satisfied with 3 led version, I can mod them to accomodate 40mm anna-6(7) optics: 2019-01-31-21-31-08
What is the total price modded for the 40mm anna optic and rethreaded to fit Convoy M21A threads?
Is the anna optic included or do we need to buy them separately?
kiriba-ru
kiriba-ru's picture
No rethread option.
Optics and pcb are available from led4power.com
Set:
Alu head modded for 40mm optics
Brass retaining ring for 17/20mm driver
Cu spacer
Stainless bezel
AR coated glass
O-rings
$31 without shipping.
VaKo
Do you have any C8 spacers individually? I have a Manta Ray C8.2 which takes Convoy C8 reflectors but also has a head that is almost double the mass.
kiriba-ru
kiriba-ru's picture
No. Can try to make one if needed.
TrueRMS
kiriba-ru wrote:
No rethread option.
If you find a way to retread to 21700 I’m in! I love the one I have already with 3x W6 bin 351D’s and it handles the heat even with a molicel P28A but I’d always be in for M0AR P0WA!
kiriba-ru
kiriba-ru's picture
Nope. Rethread is not possible.
kiriba-ru
kiriba-ru's picture
Couple of M2 aluminium sets in stock.
kiriba-ru
kiriba-ru's picture
Open for single quantities custom requests until August.
Chatika vas Paus
Stainless steel bezel for ylp gryphon g180?
kiriba-ru
kiriba-ru's picture
Dont have one on hands.
