Charger 26650...
Appreciate your detailed reply mate, I had already bookmarked and pinched all the photos out of your balance charging thread the other thread has some good info, in terms of the black balance leads, where do they attach between cells? To the magnet or on the cells themselves?
Have the hyperion balance adapter here, never even thought about changing it and buying the JST-XH leads makes it much easier than trying to find pin-outs!
yeah to the magnets then the magents go inbetween the cells and hold them together, i used 8 x 8 rea eath magnets they solder ok with a 70 watt solder iron, just dont let them bang to hard together as they will chip,
Yeah just plug the jst-xh leads straight in, they are more common and cheaper too.
I graphed the charging algo here:
Overall, it's a decent charger but never seems to stop charging so definitely not a safe one (even if the residual charge rate is very low). Not recommended for novices and even advanced hobbyists should use with care.
So they are just like most cheap chargers that ovewr charge by the looks and i quess the safest option would be to use the protected trustfire 26650 batteries or balance charge them like i do
The Xtar WP2 II charges the King Kong unprotected 26650 just fine with the addition of a magnet on top to make contact. Mine cuts off charging at 4.19v each time.
The Xtar WP2 II i gave to a family friend cuts out around 4.22 not bad also depends on the cell, some of the other trustfires and solaforce chargers are around 4.23 and my old mans imax b6 over charger's.
Ill test the TR-005 when it gets here and see if its with in a safe range before i hand it over as the above test is not to bad to me as a midrange user and it could of just been a one off.
HG-106LIX Lithium Battery Charger For 26650/18650 - $4.00 http://www.cnqualitygoods.com/goods.php?id=1546
18650 / 26650 1A Rapid Charger Kit - $8.50 http://www.cnqualitygoods.com/goods.php?id=1331
The 2nd one looks suspiciously similar to the ML-102 sold by IOS. Bit more expensive, but it apparently includes a wall-wart?
The second one is a Miller ML-103 which has a power supply port instead of the mini USB port. It comes with a power supply.
Im testing a TR-005 26650 battery charger all seam good sofar after days testing. Ill do a thread once im done.
Ive done a reveiw of the 1.5 amp Tr-005 26650 charger here:
https://budgetlightforum.com/t/-/8049
Another option, if it is 1 amp per bay it would be good, if it is 1 amp in total (0.5 amp a bay) it still would be a lot quicker to use the single bay charger i reviewed and linked above.
TrustFire Dual Channel Li-ion Battery Charger For 26650/25500/26700/18650/16340 - TR006 (US Plug)
At lest it too has a common power cord easy for us Aussie's to swap out, same for the guys in Europe And it looks like it has a female plug on the side for 12 volt cigarette lighter.
So approximately what's the charge time of a 26650 5000mAh @1A and @1.5A?
Aprox 5 hours @ 1.5 amp, but this will depend on how low you have drained the cell.
Earlier today got a reply from Manafont, the double trustfire charger is 1 amp per bay, it would be a good buy to me if you needed a 26650 charger a big bonus would be it does not have a fixed power cord like some or an external power supply with a foreign country wall plug so you can easily swap it and maybe (looks like) if it takes cigarette lighter cord with a small male plug of the end as i have heaps of spares of both.
benckie,
I’m sure you know there are plug adapters to solve your power plug adapter issue. it’s only $1. They are available with 2 or 3 prong.
Following Manafont’s instructions, I ordered the above SKU# (US plug) stating on checkout that I wanted the version with EU plug.
Not shure if the same goes for other countries.
Yeah i use cheap power adaptors or just swap out power cords as i have plenty
As Manafont eventually failed to ship the charger with the requested Euro plug, I bought the adapter and, contrary to my expectations, it makes a perfectly solid combined plug. No need to replace the molded US one.
Ive brought some usa to au adaptors for $1 shipped that work well
