WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
Thank you jon_slider !
With the help of BanL (Thanks BanL) I finally got a variety of reflectors. After trying several different reflectors from Fasttech that didn’t fit, I even cut one down on the lathe to fit but was worse than the stock reflector my KD shipment finally came in. I now have two reflectors here that drop right in to original RRT01 with no modifications.
The both produce a very nice beam compared to the original reflector. I have only tested them using a LH351D shaved dome led but I don’t expect them to be any different with a 3535 led. Nice hotspot with even spill and no visible rings.
Reflector #1 being slightly larger in diameter (19.4 mm in diameter).
Reflector #2 slightly smaller in diameter (19.3 mm in diameter).
They look identically to my eye but when measured KD list the right dimensions, one is .1 mm bigger than the other.
They are OP reflectors but are very fine ripples, barely noticeable.
To me with the shaved LH351D the smaller #2 reflector has a slightly better beam but ever so lightly. It could be it just looks better with the shaved LH351D.
There not that expensive so it might help to order both and see which one works best for you.
The best thing is they drop right in with no rings… :+1:
Great info on an alternative reflector for the Original RRT-01 to help eliminate rings in the beam
I will go ahead and order some to try out.
Thank you moderator007 for your efforts and generous sharing of information
a friend reports his stock reflector in an Original RRT-01 does not have a problem with rings in the beam using a 5000k 219c, but I certainly do have a problem with a 219b in an original RRT-01 w original reflector
I lent the Original RRT-01 w 219b to a friend, and he noticed the rings too, so Im really looking forward to trying the alternate reflectors.
It opens up some better possibilities for a run of Single N219b LED modded Original RRT-01.
woohoo!, going shopping :slight_smile:
Done! ordered 3 of each…
Awesome thanks for doing this. Ordered!
Thanks! Ordered.
Thanks! Ordered
Now that I’ve used mine so much, I wish Jetbeam would make a 18650 body for it…
I thought about modifying mine with a lathe to add so length in the narrowest part of the original tube but I’m afraid of ruining it…
Niteye eye15… :question:
Well it’s discountinued, plus I’d prefer to keep the RRT-01 and just have triple the runtime…
Thanks anyway !
But if you could find one I’m sure it’ll screw right on to the rrt-01 head :+1: unless you mean the new rrt-01 :zipper_mouth_face:
these tubes are made of UnObtanium:
yes, Eye15 legos with Original RRT-01 and Eye10, and TCR-1
X3 has the New Phat Head version, so needs to manufacture a new tube
or a custom adapter for the New Phat Head to fit something like the DSpeck UBH
http://www3.sympatico.ca/d.speck/UBH-Infopage/
For anyone who wants to run an 18650 with your original RRT-01: a Crelant 7G3CS battery tube fits nicely onto the original RRT-01’s head. Gives the RRT-01 more runtime with a lockout clicky. Overall length is roughly 120mm, IIRC . Anodize color will be off, but I use my lights for more than photo-ops.
Cheaper and much less time consuming than taking to the lathe and CNC.
The light lends itself to much improvistion. The screw in lanyard makes adding machined or 3D printed attachments easy as well. On a 3D printer, I made a twist off RRT01 lanyard cap for father-in -law that holds pills and hearing aid batteries :smiley:
I’d thought about a adapter that would thread to the head and to the tube, like sunwayman did with the V11R and V10R.
Well if I could buy a spare 18350 tube, I would try to mod it but I don’t want to ruin the light at all
The new RRT-01 tube is built very thin, not much beef for modding is my impression.
Incidentally, the threads in the old RRT-01 are compatible with the threads in the Manker E14 / Astrolux S41.
This means you can take an 18650 tube from those lights and lego it onto your old version RRT-01 head to get instant 18650 support.
There also tailcaps available for that thread pitch without without switches on them. So if you want a flat back with no switch it’s possible to do. I just tried it with parts on hand and it worked.
While the threads on those lights are the same as the threads on the RRT-01 head, it should be noted that there are more threads on the Astrolux/Manker tubes. If you want it to be watertight and cover the o-ring on the body tube you may need to shorten the threads slightly by sawing or filing off the top of the battery tube.
The old RRT01 also legos with a Convoy S2 tube, IIRC. But it requires sanding down the tube threads to make it short enough for a good fit. Or dealing with exposed threads and no waterproofing.
Now let’s find where to buy and old RRT01 :smiley:
http://www.aushunteronline.com.au/spotlights/torches-accessories/jetbeam-rrt-01-led-torch-600-lumens/
and here is a replacement reflector for the Original RRT-01
following info courtesy of Coppet:
a replacement lens that also fits 2019 RRT-01
and a black clip option that also fits 2019 RRT-01
