Well i said some think in my Beam Shot VID, but i think it should be a press and hold to turn on, just so its a bit safer, also after its ON, you should be able to SINGLE CLICK to change modes, and a PRESS AND HOLD to go DOWN in the modes, as it sucks to have to keep going up and up just to get back down, also i was thinking instead of a DOUBLE CLICK to TURBO, it might be nice to PRESS AND HOLD the button to get TURBO, but thats if they kept the SAME UI.
Yes, I think these lumenmomsters should have a better UI. The UI is easy to understand, but not as useful for this high power flashlight. Now waiting for Acebeam to make a 101,000 flashlight.
I hope they'll listen and improve their next one. I mean having 700 or 60,000 lumens at turn on is quite a difference. Without knowing what mpde it was in. Probably a physical lockout would work, but thats a workaround a $600 light shouldn't need to have.
Dude, these guys are doing things nobody else is doing. Heat pipes, improved active cooling (improved over ms12), 100,000 lumen, all this for under $600. From what I’ve seen they do listen to our recommendations. Sure Acebeam might follow up, but that’s chicken Sh@&, it’s easy to follow up on the heels of the innovator.
Oh I agree! I own a DX80 which has been great. I think with a few minor tweaks like allowing fan control on any mode, less accidental turbo activations and maybe an easier to find button (which Martin mentioned to them before it even came out) this light would be even better.
Those are all minor issues though and my only real gripe is how excited I was for their listed runtimes at 22,000 and 10,000 lumens. It appears those runtimes were only theoretical.
