New Kizer Domin Mini is out. 2.85” blade versus the 3.5” original blade length. Looks pretty nice. I don’t know if these are new or just, new to me. I like Kizer knives so I thought I would share. Not affiliated with this site or anything. I just like their selection and free shipping on any order.
I wish more companies (Chinese) would offer a Mini line. I find something with a blade length between 2 7/8” & 3 1/8” just about perfect in a folder. Not to big, so it is easily controllable; yet big enough for most any chore expected of a folder…. up to and including dressing most American big game. ymmv
That’s why I enjoy my Sanrenmu Land 811. 3” blade, 8Cr14MoV, I wish it was the Sandvik steel from the 910 series.
Washers, safer when closing it than ball bearings, at least for me.
The next knife I’d buy is the Ganzo FH51, small enough for edc yet still a usable size. D2 steel, I think I’ll like it…
What I don’t like in the FH51 is that strange cutout in the blade for your finger. First - it means it’s a small knife for people with big hands. If you have smaller hands it means that the cutting edge is further away from your fingers which can be annoying. Second - it reduces the length of the cutting edge.
I have a full sized Domin as well and I agree, it is easy to carry everyday. I have a Begleiter as well that gets lots of carry time. I find that the slimmer the knife is the easier it is to carry for me. If a smaller bladed knife is too fat I find I won’t carry it much. Just not as comfortable as a larger blade in the thinner frame.
I agree that finger choil is needless on the FH51 because the handle is big enough even for L hands. I would also prefer a longer cutting edge instead of it.
Otherwise it’s a pretty good compact flipper.
Which one do you like more the Domin or the Begleiter?
I went for the Domin because based on the photos I found online it seemed a slightly more refined design to me (thumb studs also serve as stop pins, longer cutting edge, backspacer etc.).
Yes it can, just unscrew the two screws you mentioned.
They look like Torx head screws. Just make sure you use the proper size bit with some firm pressure applied or the screw head will may strip out. :cry:
I bought a FH21 from the link you gave me & it arrived yesterday. Thanks again for the link too!
Ugh, yeah… I couldn’t tell if it was torx or hex, and used a hex key… I got one of the screws out but not the other. I don’t have a torx bit that small - gonna have to buy one.
For me a wharncliffe blade is to cut while you hold it in your hand just like grandma cuts potatoes and carrots or to pull cut material on a harder surface.
For these jobs you don’t need a long blade but a good handle and a chail can help to control the blade.
When you check your (coated) blade on users, do you ever use the whole blade anyways?
I don’t, but I don’t like a blade that’s “too short” in the handle when closed, so a choil is fine with me.
Maybe a choil-less version could be interesting but there’s enough (budget) knives out there and every month there’s some dozen more.
Try if you like a choil or leave it behind, your money will find a place to rest
It could replace my Malyshev Gnome maybe which I use every day on job, the pointy tip could scare some folks though…
My wish would be a standard clip mount as close to the butt as possible, it would ride same deep as with this clip but wouldn’t bite the palm as much.
Hmmm……Good question. I tend to lean towards the Domin overall. I like the clip a bit better on the Begleiter but I find myself carrying the Domin more often. It just fits my hand better. I wouldn’t get rid of either of them but the Domin would be my go to.
A CHEAP… Budget knife.
That fits very nicely into my mid sized hands. and is very controllable. gripping by handle. or rear of blade (IE Chef’s grip). For most of my general cutting in garage etc.
ENLAN MO9. Probably 440c steel.
Sharpens nicely. Cuts well, and doesn’t blunt to soon.
$8.50 del. last yr.
I find it in my hand more so than the Ganzo’s and Y-Start D2.
which are both bigger and better quality.
My Mora Companion has arrived. Seems like a fairly good basic fixed blade. I like the grippy rubbery handle. Will be taking it camping with me this year.
