And yes, I still think that full head design is usefull feauture because you can swap heads.
What would it add the the cost of the C8TT?
$5.
I assume it can’t be re-threaded for the 21700 C8, right?
Right.
What is the total price modded for the 40mm anna optic and rethreaded to fit Convoy M21A threads?
Is the anna optic included or do we need to buy them separately?
No rethread option.
Optics and pcb are available from led4power.com
Set:
Alu head modded for 40mm optics
Brass retaining ring for 17/20mm driver
Cu spacer
Stainless bezel
AR coated glass
O-rings
$31 without shipping.
Do you have any C8 spacers individually? I have a Manta Ray C8.2 which takes Convoy C8 reflectors but also has a head that is almost double the mass.
No. Can try to make one if needed.
If you find a way to retread to 21700 I’m in! I love the one I have already with 3x W6 bin 351D’s and it handles the heat even with a molicel P28A but I’d always be in for M0AR P0WA!
Nope. Rethread is not possible.
Couple of M2 aluminium sets in stock.
Open for single quantities custom requests until August.
Stainless steel bezel for ylp gryphon g180?
Dont have one on hands.
Only spacers or also threaded parts? If also threaded, a short tube for Convoy C8+, please.
Spacers or threaded parts that I have already made or parts for hosts that I have on hands. Drawings are preferable.
Tube is too complicated part, it needs to have perfect knurling, flatnesses, ano etc.
I understand, thank you. Are there any interesting or popular hosts you have on hand?
Dont have any modern hosts except S11 and S21. Before I got Q8, all other hosts are even older.
And something like that? For 18350 only and quad.
