I got my D18 Monday and I was sure when I first tested it that top of ramp was not the same as turbo. However, after playing with it more last night I couldn’t notice any difference in brightness double clicking at top of ramp. Need to investigate if the ceiling is too high or if I managed to find some bug. Battery charge level should be 4.0+ but I will test that too. Is there some firmware version that was delivered with top of ramp = turbo?
Mine was set to top-of-ramp = turbo as delivered. I bumped the top-of-ramp down by about 15-20 clicks.
As mentioned in another thread, on smooth ramp mode, my ‘delivered today’ D18 SST-20 4000K with brand new button top VTC6 batteries also showed no visual difference between top of ramp and turbo. However, on stepped ramped mode, there was a noticeable difference between top of ramp and turbo. I like to have smooth ramp go from moonlight all the way to turbo, anyway, so i configured that way afterward, to ensure it was deftinely operating that way. Everything else seems sweet. Amazing light. Smaller than expected. First light with Anduril, so lightning mode and candle mode are pretty neat to play with, too. Also, it fits my Maxpedition Remora EDC bag nicely!
So do I click 50 or 51 times to set ceiling to max regulated?
51 times.
The first click is the highest level, 150. Second click is the second-highest, 149. And so on.
It may seem like it’s off by one, since level 140 of 150 is 11 clicks… but it’s because otherwise there would be no way to get the highest level. It’s like how the “first century” is from 0 to 99, the second century was 100 to 199, and the twentieth century is from 1900 to 1999.
Does anyone know which tint binning the 4000K SST-20’s Hanks uses have? I’m thinking about ordering a D18 without leds and putting 18 FD2s from BlueSword in it but it would be funny if it appears Hank uses the FD2 bin.
Judging by the ones he is selling for parts it should be FB4 bin. https://intl-outdoor.com/luminus-sst20-bare-led-p-936.html
D18 has FB4 and looks like this:
In my opinion, the color is really pretty and I do not see too much sense to fight for FD2. I will just add that the Duv 0.0010 does not change too much, because at 1000 Lm the measurement gave me the same value.
All the testing seems to indicate the SST-20 in the D18 is more inline with the FD2 than FB4 tint. You should email Hank directly.
Looks a lot different above the TIRs. Pretty cool
Sweet!
Its seems that there is a little mistake on this protrotype with the AUX LEDs colors order on the external ring. It looks better like on the inner ring when yellow is placed between green and red. Pretty sure you already noticed it but worth mentionning to be sure.
its warm white not yellow, camera does not show it right
I measured my XP-L HI 4000k at 10,600 lumens at 1s with my TA lumen sphere calibrated with Maukka lights using VTC5D fresh off the charger. A bit disappointed with the output since the 7-emitter E07 makes 7,000 lumens at 1s, but the tint is very nice. The top of ramp is set the same as turbo so double click from off takes it directly to turbo. Typical Anduril lights sets the top of ramp at about 50% or so of turbo.
Does anyone else have the XP-L Hi version? I’m curious is the XP-L HI version dimmer than the SST-20 version. My M43 with XP-L HI 5D was 1,000 lumens lower than the XP-G2 5D version.
EDIT: I just realize one of the batteries was a Sofirn 2200mah and not the VTC5D. I remeasured using 3x VTC5D and got 12,400 lumens at 1s. Better but still less than what I expected.
I just took a tint measurement at turbo and got this:
CCT: 4137K
DUV: –0.0024
CRI (Ra): 73.1
R9: –18.5
Rf: 70
Rg: 97
Ra: 73.1
5D is still one of my favorite tint. Looks very perfect neutral white at night time with no hint of yellow when my eyes are adjusted to the 2700K-3000K house lights.
What did you end up getting for measuring tint/CRI?
Sekonic C-800
Does anyone know what the sustainable output is on this light?
Starting @ 14k lumens for the 5000k, what will it drop to but hold? 5k lumens?
~2,000 probably based on the charts in the OP
