When will you produce a zoomie?
We will produce zoomie light in the near feature.
A LEP zoomie?
YES!
What is the beam intensity of the 4000K and the >90CRI version?
So, does it come with a tripod and telescope, to hold the light still, and see the target 1.5 miles away?
wle
It does illuminate stuff closer by as well
I think that the beam is not that different from the BLF GT, illuminating a smaller area (about 5 times smaller in area) a bit brighter, but I still think it can be a useful illumination. I have seen the illumination that the Maxabeam gives (up to 12 Mcd), even that one can be applied as a useful beam without telescopes and such.
just saying
if the beam angle is smaller than the angular resolution of the eye, then - well i have lasers already - they are pretty bad flashlights !
Any sightings of Price?
Looks fantastic. Also interested in specs for the high CRI and 4000K varieties.
The angular resolution of a healthy human eye is about 30cm at a km, we are not there yet
HKE has a price of 259$
So is this laser as in “Light Amplification by Stimulated Emission of Radiation” or is it laser as in “tactical teeny weenie narrow spot flashlight”?
It's a laser phosphor system using a real blue laser.
lenght 119,1 mm ? probably a mistake in the specification
Lasers have speckle and are also monochromatic which makes them very bad for illumination.
This is not just a laser, it is laser phosphor, basically a higher intensity LED with a laser diode instead of a regular blue diode.
It is laser pumped phosphor.
What would be the situation where someone need a >90 CRI laser?
It’s not a CRI90 laser, the laser used here has negative CRI. It’s CRI90 phosphor.
And this item is not a laser. It is a flashlight.
there are Whitelight lasers with continous spectrum using special fibres
Saphire laser with a lot pulse width compression
the pulses are way shorter than a single wavelenght so its also white (but such pulses are extremely hazardous for any eye)
