That is fantastic news, and I think I will have to get one. The D4 is the most overpowered unmodded light I’ve encountered, so it’s sort of a worst-case scenario for thermal regulation. The ability to reflash it without taking anything apart would be incredibly helpful for thermal testing.
I still find this weird considering it even has vias to flash. Maybe it was just too similar to RampingOSv2 for him to see a reason to do it. Maybe shoot him back an email and ask him if he could do it for like $10?
Id offer to do it, but I killed one by flashing corrupted fuse bits and now that I have 2 working Anduril XP-L HI D4S with calibrated voltage I wont touch them. Im apparently alone in this feat though as TK has never had an issue that im aware of.
I read on reddit that the D4 should be soon available in the same sand color of the D18! Is this true? I wish he also add a knurling on the tube like the titanium version.
Aye. I would love Green or Titanium, but sadly I missed my chance for either of those options.
As the new D4 has flashing pads on the driver, will there be an adapter available, or will I have to get creative with some modelling clay and bare wires? After trying the improved 6/02 version of Anduril, I simply must have it on my flashlight.
It looks like you got one with a 2019-05-21 build, but I think the D4 should mainly ship with a 2019-06-05 version instead.
Muggle mode has been removed at Hank’s request. It seems to cause too much confusion. I’m kind of happy to have it taken out, TBH.
I’m hoping Hank or someone will make the pogo pin adapters commercially available, but I don’t know what will happen.
It’ll definitely be required for the Anduril version of the D4 though. It seems those are using a new tiny1634 driver, so the pogo pin adapter is the only way to flash it. A SOIC8 clip won’t work.
The RampingIOS version is still tiny85 though. That code hasn’t been updated to run on tiny1634. So if anyone wants to make sure they get tiny85, order the RampingIOS version.
Tiny85 and tiny1634 are not binary-compatible, so a .hex for one doesn’t work on the other.
The new chip is a significant improvement in some ways. It has twice as much space for code, and it has quite a few more pins available for inputs and outputs. Past designs have often been rather limited because there weren’t enough pins, and that restriction mostly disappears with t1634.
Nice!!! Sounds like it’s time for your to start writing firmware to take advantage of the new chip TK!!!
So what new features are you going to add support for to take advantage of the extra space and pins?
Some suggestions:
Support for a speaker - so when we enter lightning storm mode in Anduril the light will play the sounds of simulated thunder with each lightning flash.
Support for a sprinkler - Why just limit lightning storm mode to the sounds and sights lightning? The light should also provide rain so we get the full experience!
A calendar - so the light can sing us Happy Birthday on our Birthday (using the previously referenced speaker)!
An accelerometer - so the light can detect when it’s been dropped and then tell us so through the speaker. I’m sure we’d all like to hear our light yell out “OUCH! WATCH IT DOOFUS!!!” when we drop it.
Support for robotic legs - Why change the battery manually when our light can just sprout legs walk over to the charger and change the battery itself?
