TC66C-a powerful Type-C USB tester
I will buy one if it can discharge/charge at custom current
And i can set number of cycle( for cycle test), and export data to csv file.
Thank you guys. We will do research before we develop our products
we just make a power supply AC 220V-DC yesterday. It is interesting and you can have a look.
NEW TC66C review:
[Excellent tester, comes in the case. Control occurs with 4 buttons. On both sides of the type-c socket, there is also a microusb input. Automatic qc protocol testing menu Long press the right button input to the menu. Left button input under menu It is possible to connect the tc66 tester to the computer. To connect, you will need a microusb cable. Well, the most interesting, you can download the program to your phone, and connect via bluetooth. The tester is excellent, i advise!]
product link:[Click Here]
another review(Thank you for your support)
[Technology with a type-c connector becomes more and more, so this tester was so necessary for me) with it i can check the capacity of the charge of the superbanks, track the characteristics of the charge technology and output via bluetooth all this on the phone screen, check the wires for conductivity and evaluate the charge protocols. I like the product the ability to trigger quick charging protocols: it is immediately visible that it supports charging and where the sagging occurs. The tester is miniature, which is convenient. The small screen displays many functions of charge, characteristics of current, voltage and capacity. Purchase is satisfied! I advise the seller. Delivery took 9 days. The tester is suitable for everyone who wants to be aware of the quality of the cords used and, most importantly, check the supported protocols in the adapters for lice.]
new review(from Japan)
“Meanwhile, RD TC66C of the new product also supports measurement of USB PD 100W at a low price of $ 24.50, and also supports trigger functions such as USB PD, Quick Charge, and FCP. In addition, it is possible to connect to a USB cable and see the current and voltage with a PC, as well as to confirm with a Bluetooth connection and a smartphone application.”
quoted from “”click here”“:RD TC66Cレビュー。USB Type-Cポートに直接挿せるPD 100W対応万能テスター - AndroPlus
product link: https://www.aliexpress.com/item/32968303350.html
Seems like people all around the world are buying the TC66C.
Speaks to your product’s quality and your great reputation and customer service.
yes, all over the world , they all like that , higher praise, so it prove the quality is best
hope you like it too
these days we have uploaded many daily work video on YouTube, including repairing videos and inventing video,if you are interested in making power supply or repairing them,you can have a look at these videos.
I got my unit today. Is it possible to set it in a way that the screen with the D+/D- encoding shows at power on?
Thanks.
sorry,our AT35 and AT34 can not change the default interface
Is this your product being sold on Amazon?
https://www.amazon.com/dp/B07C9DQ4F9/?coliid=ID6ZVWDTRR5LB&colid=IKY1J73G2RN9&psc=0&ref\_=lv_ov_lig_dp_it
new share
I really like my TC66C! Is it possible to get TC66 with female USBC on both ends?
yes,but not us,it is our retailer
thank you, you can use converter but the measurement values will not be that accurate, so it is better not to do that
Just make a limited run BLF edition with 2 female connectors :)
you can have a look at this:Elistooop 10Gbps USB 3.1 Type-C type c USB-C 24Pin Female to Female Extension Adapter connector for HUAWEI Chromebook Phone
it is not our product, but I think this one will not influence the result so much.
Now that is an idea! Id like to buy a BLF edition branded USB tester. I will also consider the coupler as well.
ok, friend
thank you
