No rethread option.
Optics and pcb are available from led4power.com
Set:
Alu head modded for 40mm optics
Brass retaining ring for 17/20mm driver
Cu spacer
Stainless bezel
AR coated glass
O-rings
$31 without shipping.
Do you have any C8 spacers individually? I have a Manta Ray C8.2 which takes Convoy C8 reflectors but also has a head that is almost double the mass.
No. Can try to make one if needed.
If you find a way to retread to 21700 I’m in! I love the one I have already with 3x W6 bin 351D’s and it handles the heat even with a molicel P28A but I’d always be in for M0AR P0WA!
Nope. Rethread is not possible.
Couple of M2 aluminium sets in stock.
Open for single quantities custom requests until August.
Stainless steel bezel for ylp gryphon g180?
Dont have one on hands.
Only spacers or also threaded parts? If also threaded, a short tube for Convoy C8+, please.
Spacers or threaded parts that I have already made or parts for hosts that I have on hands. Drawings are preferable.
Tube is too complicated part, it needs to have perfect knurling, flatnesses, ano etc.
I understand, thank you. Are there any interesting or popular hosts you have on hand?
Dont have any modern hosts except S11 and S21. Before I got Q8, all other hosts are even older.
And something like that? For 18350 only and quad.
Such things are posssible.
What is the cost of copper?
Too many factors, pm details please.
Do you need pill inside or solid shelf. Do you need retaining ring for driver and driver size.
Would not like to make driver retaining threads in Cu. Can press fit brass insert.
Still in stock. Also have two quad sets with copper spacer for S11.
Few words about S2+ single pill. They are available both with convoy or special (do not confuse with “custom”, this are made special for this pills) retaining rings. Ring threads have extended length so both support 2-sided drivers. However, I can not recommend forcing AMCs down with convoy ring (even if it helps with chips cooling, you can easily damage them). Special rings have wide lip with slots, screwing them hard should be more easy and safety than thin “custom” rings. Special ring doesnt allow using driver negative pad without spring, also there might be some issues with very long cells.
Hi kiriba-ru.
Do you have in stock ledil cute 3ss lens?
