If not too late, could I get in for 20no SST-20 4000k FD, please?
20no? Well, you do not seem to want 2. From the remaining amounts, how many do you want then? LoL!
Hi Blue;
I’ll take the following:
10 pcs BeCu v.3 large and 10 pcs small
10 pcs Phosphor Bronze (v.2) large and 10 pcs small
6 x SST20 4000ºK FTD
Thanx!
We are at:
571 Large BeCu Silver+Copper plated springs
507 small BeCu Silver+Copper plated springs
975 SST-20 FD2 LEDs.
The SST-20 4000k FD2 interest list will be closed in 30 minutes, and as I will only be ordering 1000 LEDs, there are only 25 LEDs left that can be taken!
I’m serious!
Should we send PayPal now or wait for the GB to end?
@will34, I’ll be sending the rest of the PMs this evening. Just announcing the end of the SST-20 interest acquiring.
We are at:
10 LEDs per person max, so at least one person won’t hog the rest.
Sorry for repeating myself.
I’ll join in if not to late.
10 SST-20 FD2 leds
15 small springs
15 large springs
Added to the list.
There are only 15 LEDs left in the interest list.
Only 10 LEDs per person for the interest list.
Ehhh I’ll take 6.
9 SST-20 FD2 LEDs left!
Closed for the LEDs now.
You can still enter for the BeCu spring Gen 3 no problem.
We are at:
1000 SST-20 FD2 4000k LEDs
The LEDs have been ordered.
You can still all put your interest for the springs in this thread of course, since I haven’t ordered them yet.
BlueSwordM, did you consider doing something like this?
One spring provides stiffness. It can be even steel.
The other provides conductivity. Has very few coils (maybe even less than 1) of very thick conductor. Could be even plated pure copper
Can’t see the pic at all.
That's weird.
I see it.
It's hosted on Imgur, which generally works for most people.
Back on a network that doesn’t block imgur.
Wouldn’t that defeat the whole purpose of not soldering a wire to a spring?
Maybe he means extruded as a single piece, but doesn’t seem like something the machine could do?
External spring bypass. Somehow or other, that is a spring bypass sorry to say.
By the same principle, a solid copper conductor spring could be designed to couple with a proper elastic material spring like steel. Somehow or other again, for this to work practically the coils would need to be soldered or spot welded at the base and the top somehow.
Cheers :-)
The copper spring could also be on the inside, and so the more resilient steel would protect it from damage.
In my experience doing inner coiled wire spring bypasses, which is more elegant but also more tricky than outer, when properly done they're long-lasting. By the same principle an inner copper spring head connected to an outer steel spring would work fine. Pretty sure.
Is it possible to design a steel spring and a copper spring/coil to be used together as a set in a way that would protect the copper coil from plastic deformation? Also, for me anyway, if it will compete with a large/small pair of BeCu springs, then the steel spring must be coated some way to make it easier to solder. And, with the added complexity, would it be significantly cheaper than a set of BeCu springs?
Modded Q8 with inner coiled copper (~ .040” / 1 mm) and outer nickel steel spring. Capped with brass terminal lugs. Soldered beneath the caps and puddled at base.
Gave very satisfactory results.
Tedious work and if done again, would counter coil the inner part (not to bind in compression state).
Much easier and cleaner w/ BeCu. Also, my experience with silver, excellent solderability.
