【convoy】H4 and B35AM options are updated
And anyone tried to unwrap the Lii 40A out of this yellow plastic foil? Will it fit then?
currently not
i have to improve this in the next batch
cause at first there are only LG SAMSUNG TESLA or SONY 21700 in China ,
i dont know other brands have a little large diameter ,sorry
Simon,
I am sure you are pretty busy but I wanted to know if
you were able to fix the driver?
No worries Simon. It's not your fault but the "others" do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 - 21.7mm). However, a minor increase of the tube's inner diameter might be a nice option for future batches.
The diameter of the (2) Molicel P42A 21700 batteries from Li-ion warehouse wasn’t that large. Granted the spec sheet does say 21.7mm Max.
So for those us with existing drivers that include the bad values in the firmware, it’s just a matter of flashing the latest build from the code repo yes? Or would this require tweaking the fuse values prior to this?
Hi Simon,
Any plans to bring out colored versions of the S21A?
To all others: are you interested in this, and which color(s) do you like most?
My color preference (hi to low): Purple, Red, Green, Gold/Yellow, Blue, Silver, Orange, Cyan.
With metal switch :person_with_crown:
Concerning body colours:
Urban camo or olive green (natural anodization colour).
I prefer non-reflective rubber caps but metal caps might be a nice option for later modification.
I would be interested, but I have a question.
I see the S2+ comes in colors, but it’s only a host. I’ve never taken a flashlight apart before. How easy is this to do to swap the parts into a new color? The LED and circuits scare me a bit. I don’t want to damage anything or break the waterproofing.
Also. Is a metal switch as waterproof as the rubber? What are the pros and cons?
S2+ colored is also available as a complete flashlight. Look at Simon’s Convoy flashlight store. Plenty of options. So, if you’re hesitant to do it yourself…
Assembling a host is not difficult if you’re used to holding a soldering iron and know about blue=minus red=plus :wink:
Metal switch is maybe a bit less waterproof, I don’t know. It will stand a few drops of water as long as you stay above sea level :+1:
I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
If it requires soldering I’ll definitely just get a full light. I’ve never soldered anything before.
Is the metal switch just without a rubber cover?
I have tried a lot, but it has not been solved yet.
I want to introduce other firmware, such as bistro, crescendo
yes ,but anyway it’s better to change it to 22mm inner diameter
thanks for your understanding
oh ,i think i will launch more color version in the future
is it hard to make different colours?
i also hate black too because all my flashlight are black and it’s boring look.
think i have over 100 flashlights now
Excellent, can’t wait ! :+1:
+1
+1 for color variety.
I prefer the dull rough finish in OD green.
