That sst-40 test looks accurate enough, 4250 for the XHP50.2 is very close to what i’d expect a xhp70.2 to do in that form factor unless they go with an expensive driver but with probably double the CD.
Gonna heat up way too fast with an XHP70.2 too.
plus, 3v xhp50.2 is probably going to keep the cost WAY down.
Let’s see if I understand correctly, the XHP50.2 may have around similar lumens as the SST40, but will have a bit more floody (but smoother) beam pattern than the SST40. Also XHP50.2 may (or may not) have a nicer tint than the SST40?
SST40 at low brightness levels will look a bit yellow/greenish.
XHP50.2 beam tends to have a hotspot that’s cooler and a corona/spill area that’s somewhat warmer.
The 50.2 is over double the lumens of what the SST40 can do because it’s a bigger led.
SST40 die is 2mm x 2mm = 4mm2
Xhp50.2 die is 2.94mm x 2.94mm = 8.64mm2.
The smaller die size of the SST40 means it has a narrower beam angle which makes a smaller hot spot and has longer throw.
The 50.2 has much more lumens (making the spill light brighter), but the extra brightness does not compensate enough to give similar throw. It has less throw distance.
The tint on the 50.2 and 70.2 are always a bit wierd due to their flip chip design. Their coronas are always yellow compared to the hot spot.
The older xhp50 had the same color hot spot and corona which looked nicer, but they had a pronounced donut hole beam pattern in SMO reflectors.
So the 50.2 has the weird yellow corona, but at least the hot spot looks smoother with a SMO reflector. It’s the better trade off. I don’t notice the yellow corona much any more.
I can’t comment on the SST40 tint. I don’t have one.
