There is also a list of BLF flashlights somewhere, forgot who created it.
I didn’t know that the FT02 has Narsil, it is not listed in the item description on banggood.
edit:
I had both the S42 and the BLF A6 - were there maybe several revisions of either or both lights? I am fairly certain that these lights didn’t have the same firmware when I had them. The S42 was horrible to use, the A6 was good. both are gone now, so can’t check.
Hi acab, you probably mean The BLF Special Edition Lights - Master List?
I couldn't find the proper information for FT02 firmware either, so I strikethrough on the list.
As for the S42 and BLF A6, I have them both @ home and will check there UI's later on the evening ...
Thank you teacher. I’ve also added the upcoming LuckySun BLF-D80 v2 with Bistro and I’m confident many more FL with BLF DNA will follow in the near future :FACEPALM:
I think the very fluid nature and the many revisions of each light make it interesting but also difficult to collect input.
For example, unless I flashed the firmware myself, I would have no idea which version is on each flashlight. A user could check all the lights and write down features or compare them to a U/I sheet…
As one can see, I don't believe it's difficult to collect all the flashlights containing BLF members firmware (and I will do my best to keep maintaining it). Pointing to their many revisions is indeed another thing as you say it, but that’s not the main purpose of this thread. It’s all about listing ALL the flashlights containing BLF firmwares @ one easy to reach place and for easy reference. I just want to make this list as comprehensive as possible :D
Tom E makes it a bit easier with his Narsil firmware, as he is using version numbers and even has a build in version check into the flashlights itself. ToyKeeper on the other hand has the easy following up going on, with her amazing work in the firmware repository on launchpad.
Although I think this list is as good as complete (for now), the only person that can really tell for sure is ToyKeeper herself.
