Latest release Vapcell 21700 5600mah 12.5A battery
depends on the cell
yes, ICR protected cell
and
no, INR unprotected cell
Is the Vapcell IFR26650 2600mAh 55A/75A available? It is grabbing some attention at E-CigaretteForum in this thread I opened: Vapcell IFR26650 2600mAh 55A/75A (red, LiFePO4) reviewed.
Tad off topic of course, just to claim the attention of vapcell Dennis.
Cheers :-)
this is what is available near me
but you would need to google your area, Im in California, not Spain.
Received my 14500 cells the other day, sadly it doesn’t work in the Eagtac but does in the Reylight. Oh well, I’ll keep using the efest cells in the Eagtac.
Runtime is much longer that the 800mah efests I have. Very pleased with these.
Hey Barkuti, Thanks you very much
Vapcell IFR battery have many in stock,
Seriously? When I open the IFR26650 sales page it says Sorry, this item is no longer available!
https://www.aliexpress.com/item/32970825706.html?storeId=1084158&spm=2114.12010612.8148356.4.1115261c22zGDy
please check it
where are you from?maybe can not ship to your country?
His location says he's from Spain.
Curious, when I open the item via the “item link” vapcell Dennis submitted (https://www.aliexpress.com/item/32970825706.html) the ad works, but when I use https://www.aliexpress.com/store/product/-/1084158_33000300196.html it doesn't. Suffice to say I block location, I am using an “outdated” browser (this is what “a few months old” software is considered now) and I hate all those links full of tracking shit and other crap. I also refuse to use CRapplications.
Right now every time I go to a store in AliExpress I see this with sickly frequency:
Other Vapcell item links work fine, though.
Where do you get the “item” links? Like this: https://www.aliexpress.com/item/32970825706.html
oh,sorry, now it is ok
https://www.aliexpress.com/item/33000300196.html?storeId=1084158&spm=2114.12010612.8148356.8.1115261ctwcWFY
I’m not responsible for retail websites.
If there is a problem, please contact customer service, which will solve it faster.
Thanks, could you let me know why it doesn’t work in the Eagtac
The head doesn’t allow it. Looks like button top only.
EagTac
Reylight
I dont have those lights, so I cant check… this is just a guess:
probably the button on the Vapcell is shorter than on the Efest
and if the D3a has a raised ring around a positive contact button in the head, (physical anti reverse polarity), the battery + cant reach the + contact in the D3a head…
Im guessing the Reylight either uses a spring at the positive contact, and or does not have the raised ring.
a pic of the inside of the two lights heads, and of the two batteries standing side by side showing the height of the buttons, might shed some light on the issue.
bingo! the positive on the ET head is recessed, the positive on the ReyLight is raised
a small magnet on the Vapcell might solve the issue with the ET recessed + button…
but caution! we dont want the magnet to short the positive contact to the ring, if it is ground…
I thought about that but it’s not that big of a deal. I don’t carry the EagTac that often, I mostly carry the Reylight.
good attitude :slight_smile:
and thanks for the pics
can you please also show the two batteries positive contacts?
Im trying to see if the Efest button is taller
Sure gimme a sec……
Vapecell is shorter. This is an older trustfire which is the exact same size wise to the efests. The efest is in a light at work currently.
You could add something like this to the driver but that take away the reverse battery protection (second pic). I would assume it probably doesn’t have a electronic protection that’s the reason it has a mechanical protection. So you’ll have to be carefully to make sure the battery is inserted correctly.
I was actually thinking just a dab of solder should do the trick lol.
