Vapcell the highest and real capacity 18650 3600mah cell for flashlight
599 posts / 0 new
BOO5TED
BOO5TED's picture
Last seen: 6 days 16 hours ago
Received my 14500 cells the other day, sadly it doesn’t work in the Eagtac but does in the Reylight. Oh well, I’ll keep using the efest cells in the Eagtac.
Runtime is much longer that the 800mah efests I have. Very pleased with these.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
vapcell Dennis
vapcell Dennis's picture
Last seen: 8 hours 38 min ago
Barkuti wrote:
Is the Vapcell IFR26650 2600mAh 55A/75A available? It is grabbing some attention at E-CigaretteForum in this thread I opened: Vapcell IFR26650 2600mAh 55A/75A (red, LiFePO4) reviewed.
Tad off topic of course, just to claim the attention of vapcell Dennis.
Cheers Smile
Hey Barkuti, Thanks you very much
Vapcell IFR battery have many in stock,
Barkuti
Barkuti's picture
Last seen: 6 days 11 hours ago
Seriously? When I open the IFR26650 sales page it says Sorry, this item is no longer available!
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
vapcell Dennis
https://www.aliexpress.com/item/32970825706.html?storeId=1084158&spm=211...
please check it
vapcell Dennis
where are you from?maybe can not ship to your country?
raccoon city
raccoon city's picture
Last seen: 9 hours 35 min ago
Location: Palm Desert CA ~ West Coast is the best coast
His location says he's from Spain.
Barkuti
Barkuti's picture
Curious, when I open the item via the “item link” vapcell Dennis submitted  (https://www.aliexpress.com/item/32970825706.html) the ad works, but when I use https://www.aliexpress.com/store/product/-/1084158_33000300196.html it doesn't. Suffice to say I block location, I am using an “outdated” browser (this is what “a few months old” software is considered now) and I hate all those links full of tracking shit and other crap. I also refuse to use CRapplications.
Right now every time I go to a store in AliExpress I see this with sickly frequency:
Other Vapcell item links work fine, though.
Where do you get the “item” links? Like this: https://www.aliexpress.com/item/32970825706.html
Smile
vapcell Dennis
Barkuti wrote:
Curious, when I open the item via the “item link” vapcell Dennis submitted  (https://www.aliexpress.com/item/32970825706.html) the ad works, but when I use https://www.aliexpress.com/store/product/-/1084158_33000300196.html it doesn’t. Suffice to say I block location, I am using an “outdated” browser (this is what “a few months old” software is considered now) and I hate all those links full of tracking shit and other crap. I also refuse to use CRapplications.
Smile
oh,sorry, now it is ok
https://www.aliexpress.com/item/33000300196.html?storeId=1084158&spm=211...
I’m not responsible for retail websites.
If there is a problem, please contact customer service, which will solve it faster.
vapcell Dennis
BOO5TED wrote:
Received my 14500 cells the other day, sadly but does in the Reylight. Oh well, I’ll keep using the efest cells in the Eagtac.
Thanks, could you let me know why it doesn’t work in the Eagtac
BOO5TED
BOO5TED's picture
The head doesn’t allow it. Looks like button top only.
EagTac
Reylight
jon_slider
jon_slider's picture
Last seen: 14 sec ago
I dont have those lights, so I cant check.. this is just a guess:
probably the button on the Vapcell is shorter than on the Efest
and if the D3a has a raised ring around a positive contact button in the head, (physical anti reverse polarity), the battery + cant reach the + contact in the D3a head..
Im guessing the Reylight either uses a spring at the positive contact, and or does not have the raised ring.
a pic of the inside of the two lights heads, and of the two batteries standing side by side showing the height of the buttons, might shed some light on the issue.
bingo! the positive on the ET head is recessed, the positive on the ReyLight is raised
a small magnet on the Vapcell might solve the issue with the ET recessed + button..
but caution! we dont want the magnet to short the positive contact to the ring, if it is ground..
BOO5TED
BOO5TED's picture
I thought about that but it’s not that big of a deal. I don’t carry the EagTac that often, I mostly carry the Reylight.
jon_slider
good attitude Smile
and thanks for the pics
can you please also show the two batteries positive contacts?
Im trying to see if the Efest button is taller
BOO5TED
BOO5TED's picture
Sure gimme a sec…..
BOO5TED
BOO5TED's picture
Vapecell is shorter. This is an older trustfire which is the exact same size wise to the efests. The efest is in a light at work currently.
moderator007
moderator007's picture
Last seen: 1 hour 28 min ago
You could add something like this to the driver but that take away the reverse battery protection (second pic). I would assume it probably doesn’t have a electronic protection that’s the reason it has a mechanical protection. So you’ll have to be carefully to make sure the battery is inserted correctly.
http://budgetlightforum.com/comment/1448348#comment-1448348
BOO5TED
BOO5TED's picture
I was actually thinking just a dab of solder should do the trick lol.
moderator007
That work too, but it tends to oxidize in a few uses. Works fine as long as you clean it ever now and then.
CRX
CRX's picture
Last seen: 7 months 4 weeks ago
You’ll probably find the MRPP ring is soldered onto the driver.
Barkuti
Barkuti's picture
My low temperature Bi50Pb32Sb18 blob converted cells do not suffer from oxidation on the top.
How much money are you paying for Eagtac or that sort of manufacturer flashlights? In my opinion paying good money for something and receiving such a piss-poor “@#$% consumer battery choices” reverse polarity protection solutions is very bad.
Smile
varbos
Last seen: 6 days 20 hours ago
Vapcell Dennis wrote:
USD6.99/pair Slightly flawed vapcell 18350 1100mah 9A battery
08-21/2019
Vapcell 18350 1100mah 9A battery test by HKJ and mooch, it is the best 18350 battery in market
Hi, in the thread title you are saying $6.99 per pair – meaning two cells (ie $3.50 per cell).
However your Aliexpress listing says $6.99 for “one piece”.
https://www.aliexpress.com/item/4000108417629.html
Can you clarify how many cells are included?
$6.99 = two cells?
$7.99 = four cells ?
vapcell Dennis
08-21/2019
$6.99 = two cells?
sorry, I correct it . usd7.99 /Pair
Umpi2000
Last seen: 3 hours 57 min ago
Are those suitable for flashlights?
Barkuti
Barkuti's picture
I often see these claims in battery advertisements, and sorry to say but that is wrong. Batteries can be used to power up a multitude of things. I could use a battery to power up a personal vibrator, for example.
The pertaining question here is, ¿is the flashlight and its driver designed to make use of such battery? Also, ¿is the flashlight user knowledgeable and responsible enough to properly take care of it?
I am not aware of flashlights designed to be powered by 26650 LiFePO4 cells. This could be useful for very low Vf leds and linear or unregulated drivers.
TheOnlyDocc
TheOnlyDocc's picture
After the very good experience with the Vapcell support during my last order i ordered the 18350 cells now. DHL did not leaf a message that the package is ready for pickup in the Post office 150m away.
So the package was send back. Instead of asking me for money (thats what AE usually does) the Vapcell Support contacted DHL and managed a second delivery for free. 1A Support and fast help.
And not only the support is great i can only say good things about the cells. Untill the next buy.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
d_t_a
Last seen: 14 hours 56 min ago
I’d like to check out the Vapcell S4 Plus charger, but going to the AliExpress link, it indicates “cannot ship to my country”…
Barkuti
Barkuti's picture
Oct 21th,2019
Hello friend,
We have Vapcell S4 Plus 4 slot chargers
1. 3A 3A 3A 3A each slot , 12A in total
2. Discharge/Capacity Test/ Repair function
3. Enough space for 21700 batteries
We are looking for professional testers,Pm me!
And Do you want to have a try for new technology charger?
Aliexpress usd37.99/ pcs,free shipping, click the link
https://www.aliexpress.com/item/4000249374391.html
 Why not LiFePO4?
Like above here's the link “international/english version” fixed: https://www.aliexpress.com/item/4000249374391.html
contactcr
Last seen: 9 min 35 sec ago
Vapcell
When you add new info to this post please add a new post to the end of the thread at the same time as you modify the first post that way people will know what was changed and get a proper notification
vapcell Dennis
contactcr wrote:
Vapcell
Thank you very much. We will improve
vapcell Dennis
Oct 21th,2019
Hello friend,
 Why not LiFePO4?
Like above here’s the link “international/english version” fixed: https://www.aliexpress.com/item/4000249374391.html
Well, do many people use IFR batteries If there are many demands, we will upgrade the other version, plus the IFR battery and 4.35v battery
By the way ,vapcell U2 can charge IFR battery Big Smile
