Dang, it looks like I’ll be spending money on a Folomov Pen L1.
I like the C2 that I’ve had for a couple weeks.
That Pen L1 is rather interesting. The specs listed are a little weird though – It looks to use a specialty internal USB charged 10900, but the text also says it runs on 10440 and 10400, depending on where you look.
That Pen L1 is rather interesting. The specs listed are a little weird though – It looks to use a specialty internal USB charged 10900, but the test also says it runs on 10440 and 10400, depending on where you look.
I noticed those discrepancies, also.
I suspect that they copy and pasted from the C1 information and didn’t proof read very thoroughly. The published output specs are the same for the C1 and L1, and they probably shouldn’t be the same.
It does look like it uses a really special-looking 10900 lithium ion battery, which has a built-in charging port (otherwise, no current charger can charge 90mm length batteries (maybe a magnetic charger with a low-charge current will work)
I wonder if the 10900 is about twice the capacity of 10440, since it looks to be about twice as long?
Or maybe can we substitute 2x AAA NiMh/Alkaline batteries (but voltage may be too low?)
Folomov L1 does not work (properly) with 2xAAA eneloop (low modes only)
just tested on mine
Thanks for testing!
Ok, I supposed if the 10900 battery goes bad, then another option could be to use a 10440 battery, and then use a dummy AAA battery to connect with it then..
just tested on mine
Thanks for testing!
That should work fine assuming lengths are proper.
Sofirn hat mir einen Code für ihre neue Kopflampe gegeben, den ich mit Euch teilen darf! er wird bis zum Wochenende gültig sein (vielleicht ein paar Tage länger – aber nicht fix) – Also nicht allzulange überlegen
Die Sofirn SP40 ist eine leistungsfähige Kopflampe. Sie verfügt über eine Akkustandsanzeige durch einen beleuchteten Kopfschalter, eine Temperatursteuerung und eine maximale Leistung von bis zu 1200 Lumen.
Die CREE XP-L-LED mit ihrer neutralweißer Lichtfarbe erzielt eine Reichweite von 136 Metern. Der Kopfschalter bietet 4 Leuchtstufeneinstellungen.
Die Lampe wird mit einem 18650 Li-Ion Akku betrieben bzw. über die mitgelieferte Adapterhülle auch mit einem 18350 Li-Ion-Akku.
Die SP40 ist hergestellt aus einer 6061 Aluminiumlegierung mit eloxierter Oberfläche und wasserdicht nach IPX7. Sie eignet sich hervorragend für eine Vielzahl von Outdoor-Aktivitäten wie Wandern, Camping, Erkundungen oder auch für die Gassirunde.
Lieferumfang: Sofirn SP40 LED Kopflampe, Kopfband, 1x 3000mAh 18650 Akku, Benutzerhandbuch, O-Ring, USB-Kabel und ein guter Kundenservice.
all new deals are also posted here: deals.m4dm4x.com if you do not find what you are looking for :
There's something odd with the MT07 "Buffalo". Banggood says the CW is 8,000lm (N4 flux bin) and the NW is 4,500lm only (N2 flux bin). I wonder what "upgrade" version they are offering? HaikeLite could have used the P2 flux bin for the MT07 as they did with the upgraded MT09R. Maybe Banggood's got wrong information listed on their website?
I just noticed that the published outputs for the L1 are the same as for the EDC C1, even though the battery in the L1 is 2x as big.
This doesn’t seem likely that that the two lights have the same capacities.
Anyone know the actual specs for the L1?
got both colors - funny how the color change with different lightsource
groupbuy: http://budgetlightforum.com/node/67157
ask MARTIN@M4DM4X.COM - i will save you money!
How do I get a discount code for the Pen L2?
the best prices can´t be public most times - so i have to put them behind the membershipagreement to stay private
ooor you send me a PM or mail as mentioned in my signature
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
I like that the Pen L1 is substantially shorter than a (2) AAA light.
Those errors will confuse a lot of people.
Folomov Pen L1 webpage on Folomov's website
http://www.folomov.com/en/content/?141.html
Looking to purchase an Opus BT-3100 on banggood, but the code on your blog has expired
Nightwatch NI40 interest list started
just tested on mine
Thanks for testing!
Click this to go to signature links. I'm still around, just not reading many new threads.
too soon to market perhaps?
What product and why?
I can see in the description XHP35.2, suspecting a typo…
[WTS] HID host: http://budgetlightforum.com/node/68693
[WTB] Interesting LEDs:http://budgetlightforum.com/node/68968
fixed the typo - thanks!
Amazon.DE: 50% auf Sofirn SP70 KIT
Servus mitnand!
Ich habe von Sofirn einige Codes bekommen für die:
Sofirn SP70
5500 Lumen CREE XHP70.2 LED
mit 26650 Akkus
bei Interesse bitte per mail anfragen!
Martin@m4dm4x.com
BETREFF: Amazon SP70 KIT deal
Signed on for the interest list of the Nightwatch NI40.
What is the color temperature for the SST40 NW and the XHP50.2 NW? Is it 5000K or is the SST40 just a dedomed 6500K?
My Youtube channel: Alllightson Reviews
My 7th Old lumens contest build: Matainvoy ML18S, Built video
My reviews: Sofirn SP31 V2, Nightwatch NI40, Sofirn C8F 21700, Brinyte WT01, Sofirn SD05,Ti AAA keychain, Sofirn SP33 V3, Skilhunt M150
My Youtube video-reviews: Brinyte WT01, Sofirn SD05, Ti AAA keychain, Sofirn SP33 V3
FW3C and FW3A SST20 4000k available!
veröffentlicht am 13. June 2019 in flashlights von m4d m4x
Hello my dear friend!
Neal listed new variants of the great FW3A:
you find my codes in my deals list
FW3C COPPER POLISHED
Estimate ship start at July 1st.
FW3A SST20 4000K 95CRI
Estimate ship start at June 24th.
LIMITED AMOUNT!!
Do you have any deals on a Sofirn SF14uv ?
let me see
Ciao Amazon Italia, Ciao Sofirn!
Hello my dear friends!
Sofirn started to sell via Amazon.it (my Afflink)
-> Every time you use my Affiliate link helps me to get better deals!
To celebrate i got some codes for my italian friends!
valid until 17.6.2019 (or when sold out)
Sofirn SP36 LED flashlight 6000 Lumen
Sale Price: €89.99
Discount Price: €55.99
Code: SofirnSP36IT
LINK: https://amzn.to/2WFKRdi
SP31 V2.0 1200 Lumen led tactical flashlight
Sale Price: €35.99
Discount Price: €25.19
Code: SofirnSP31IT
LINK: https://amzn.to/2KOjFlw
SP32A V2.0 1300 Lumen LED flashlight
Sale price: €36.99
Discount Price: €25.89
Code:SofirnSP32A
LINK: https://amzn.to/2WJZIDC
Sofirn SP33 2500 Lumen flashlight
Sale Price: €45.99
Discount Price: €32.19
Code: SofirnSP33IT
LINK: https://amzn.to/2WJ1sND
Amazon.DE deal: Sofirn SP40
Servus mitnand!
Sofirn SP40
Mein Link: https://amzn.to/2MLMOAw
regulärer Preis: 29,99 mein Preis: 20,99
CODE: SofirnSP40
Do you have any deals for the Acebeam w30?
welcome to my newest groupbuy:
(the links take you to the shop for detailes information)
Blunish Gray Convoy S11
with SST40 or XHP50.2
I got some new deals and a groupbuy for you:
(ALL deals are available in MY DEALS LIST FOR MEMBERS)
Convoy S3
7135*8 XM-L2 U2 1A / T6 4C 3/5Modes EDC LED Flashlight 18650
CODE: BGCCS3 PRICE: $10.99
NEW Convoy L2
XPL HI Two Cells Version – 1000LM 26650 4Mode LED Flashlight
MANY LED CHOICES!!!
CODE: BGMODE PRICE: $34.99
HaikeLite MT07 Buffalo
XHP70.2 8000LM CW/NW
High Power LED Flashlight
Upgrade Version
CODE: BGEMT07 PRICE: $64.99
ADEASKA A10 Mini
USB Rechargeable Portable Magnetic Li-ion Battery charger
now in PRESALE US$ 4.99
Nitecore P30
Xp-l Hi V3 1000LM Long Range LED Hunting Flashlight 618M
(Deal is available in MY DEALS LIST FOR MEMBERS)
HaikeLite HT08
XPL HD 5000K 850Lumens Mode Set Zoomable Tactical LED Flashlight
i run a giveaway for my youtube channel:
https://youtu.be/k2IdHSadm6s
https://www.banggood.com/HaikeLite-MT07-Buffalo-XHP70-5000LM-CWNW-High-P...
