✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy + Diffuser Cap - $89
1526 posts / 0 new
freeme
freeme's picture
Last seen: 3 hours 27 min ago
List updated.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
wolfstyle
Last seen: 1 hour 34 min ago
Interested
pendo
Last seen: 5 months 5 days ago
Interested
Tranquilator
Last seen: 14 hours 38 min ago
Interested
adam7027
Last seen: 3 weeks 6 days ago
Texas_Ace wrote:
In my testing the 3 channel vs 2 channel efficiency difference was not nearly as much as many people used to think.
That said the 3 channel will have a fairly small window in the low/midrange where it has a bit of an advantage simply because it has a channel specifically designed for that output level.
At other output levels the only real difference is the input voltage.
Honestly there it is not even worth talking about driver efficiency. We are talking about a ~10% change in efficiency one way or the other depending on the exact output level. Considering the LED’s have a tolerance of 12% themselves there are simply better things to worry about.
I think, that if the second channel could be more powerful, the difference in the efficiency (both output and heat wise) could be worthful. For that many emitters (18), I think, 7×7135 is not enough – something like FET + 15 (or even 24) + 1 (or 2) could be better, as it would let the emitters run still fairly efficient on the mid-high output levels.
I took a look at maukka’s output test for SST-20 4000K, and with ~0.5A per LED, that is about 120 lm/W.
If I count 40W for a 18650 battery, and I multiply it by 4 (160W for the whole battery holder), then I divide with 18, that is still almost 9W per emitter, which is maybe around 2.6A per emitter, when I only calculate with the FET channel, and that is less than 80 lm/W then.
Maybe the XP-G3 variant could be driven harder with more efficiency, but I think, it would worth to design a 3 channel driver if SST-20 is also considered.
I know, that placing so many 7135 on the driver board would be difficult, but I think, a triple channel FET + 24 + 2 driver would be a very good fit for the MF01S.
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 16 min ago
If I count 40W for a 18650 battery, and I multiply it by 4 (160W for the whole battery holder), then I divide with 18, that is still almost 9W per emitter, which is maybe around 2.6A per emitter, when I only calculate with the FET channel, and that is less than 80 lm/W.
The other end of this is that by the tint significantly improves when the FET kicks in, so switching to that earlier helps tint consistency and quality. At low current levels the SST-20 has a noticeable green hue. I would actually consider a 1 channel FET driver for the SST-20 if the low modes could be improved.
You edited the post I see.
As my testing of PWM efficiency showed, the old thinking that you could simply take the efficiency at 100% duty and apply it to lower duty’s is not how it works in the real world. The LED does not get as hot and thus the efficiency is improved at lower duty cycles.
For example at 50% duty it was only 10% less efficient then a constant current at the same power IIRC.
Although keep in mind that 10% was purely 10% more lumen output, it is not factor in the efficiency loss from the driver ect. With driver losses factored in the difference would be even less.
adam7027
Good to know – then favoring better tint is not that costly to efficiency, as I thought before.
Dep668
Last seen: 8 months 4 days ago
Potentially interested in 3.
ToyKeeper
ToyKeeper's picture
Last seen: 2 weeks 19 hours ago
Can confirm. The tint isn’t very good until the FET kicks in. So below ~600 lm it’s not what I’d call white. But above ~600 lm, the tint is very nice. People who like a lot of light will probably love this thing.
Th558
Th558's picture
Last seen: 29 min 46 sec ago
Do you mean per LED or total output?
ToyKeeper
ToyKeeper's picture
Total output of the MF01S. It can’t drive just one LED at a time.
Th558
Th558's picture
Ok that’s alright then. My most used modes on the MF01 are 2 and 4 which are both over 600 Lumen. Btw when u say green do you mean greener than the nichia MF01?
freeme
freeme's picture
Th558
Th558's picture
Looks quite bright. Any info on the lumens. I’ll buy it if the 95 cri can do 12k.
Flying Luminosity
Flying Luminosity's picture
Last seen: 1 year 6 months ago
Interested in Hi CRI.
mkdive
Last seen: 5 months 3 days ago
interested
SKV89
Last seen: 5 days 15 hours ago
Don’t like the Christmas tree color aux lights. Can we choose aux light colors?
boomermax
Last seen: 1 year 8 months ago
sign me up
mortuus
mortuus's picture
Last seen: 10 hours 53 min ago
u dont like red? its nice too look at.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
JordanZHP
Last seen: 1 day 8 hours ago
I think they were referring to the mixed three color aux leds in the video.
AgentWhiteBread
Last seen: 5 months 6 days ago
I’m in for one. Thank you!
whipskirtayeyay
Too late to jump on this train? I’d definitely be down for (1) of these!
freeme
freeme's picture
[June 11, 2019]
What do you think about the MF01S design after viewing the video?
We would like to hear your views.
freeme
freeme's picture
There are four colors LEDs embedded on the board.
3.9v or more color: green + pink + blue
3.3v-3.9v color: pink + blue
2.9v-3.3v color: red
2.9v or less: OFF
SKV89 wrote:
Don't like the Christmas tree color aux lights. Can we choose aux light colors?
SKV89
Personally, I don’t like the green. Makes it too Christmas toy like. I would prefer another color such as orange or warm white over green.
Th558
Th558's picture
Yh too many colours. It should be one colour at a time.
Edit: actually it doesn’t look to bad but the guy above is right. Green should be replace with something else. Maybe warm white?
wolfstyle
Agreed one color at a time. How about
3.3v-3.9v color: yellow or amber
2.9v or less: OFF
McLight
McLight's picture
Location: German rain does not fall, our rain occupying the area.
Aux color status showing depended on the Volts is a good idear, but bling bling overload especially Pink is a “No Go”..
Would be nice to choose the color of Aux..
In GoD & Trance we trust, the rest pay Cash!!
Relampago
Relampago's picture
I like the green and blue. Being able to choose colors would be the best choice.
“Electricity is really just organized lightning”
― George Carlin
scr79423
Last seen: 1 hour 17 min ago
I agree, one color at time, if all aux colors are on at the same time it will look hideous lol
