Test/review of Vapcell IFR26650 2600mAh (Red)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 3 days ago
DSC_7742
Official specifications:
  • Model: Vapcell IFR26650 2600mah 55A/75A
  • Size: 26.6*65.1mm
  • Nominal voltage: 3.20V
  • End-of-charge voltage: 3.60V
  • End-of-discharge Voltage: 2.0V
  • Typical Capacity: 2600mAh (0.2C discharge)
  • Min capacity: 2500mAh (0.2C discharge)
  • Weight: Max:90g
  • Internal resistance: Max:5mOhm AC 1kHz
  • Standard Charge: 2500mA,CCCV 100mA cut-off
  • Charging Time: 1.5hours(standard charge)
  • Quick Charge Current: 12000mA
  • Max Continuous Discharge Current: 55A
  • Max Discharge Current: 75A under 80°C
Vapcell%20IFR26650%202600mAh%20(Red)-info
A large LiFePO4 cell that can handle very high current.
DSC_7740 DSC_7741
DSC_7743 DSC_7744
DSC_7745
DSC_7746
DSC_7748
Vapcell%20IFR26650%202600mAh%20(Red)-Capacity
The two cells tracks nicely. My test only goes to 30A and the cell has no problems with that.
Vapcell%20IFR26650%202600mAh%20(Red)-Temp-20.0
Vapcell%20IFR26650%202600mAh%20(Red)-Temp-30.0
At 30A the cell do not get very warm.
Vapcell%20IFR26650%202600mAh%20(Red)-CapacityTimeHours
Vapcell%20IFR26650%202600mAh%20(Red)-Energy
Vapcell%20IFR26650%202600mAh%20(Red)-TripCurrent
Vapcell%20IFR26650%202600mAh%20(Red)-Charge
Vapcell%20IFR26650%202600mAh%20%28Red%29-Pulse-1A-30-30-2V-IR
Here I calculate the internal resistance by turning 1A on/off during a full discharge.
Conclusion
The cell looks good, it has the rated capacity, and can deliver a lot of current at a stable voltage, but as always with LiFePO4 the voltage and capacity is lower than regular LiIon.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
vapcell Dennis
vapcell Dennis's picture
Last seen: 2 days 2 hours ago
Thanks HKJ very much. Smile
The temperature rise of 30A discharge is very small, which means that it can discharge with larger current.
I want to make a comparison about A123 26650 M1B 2500mah and this vapcell battery, but I can’t find A123. Could you add it in?
Thanks
HKJ
HKJ's picture
I have the data, I will see when I can get it published.
vapcell Dennis
Thanks
Barkuti
Barkuti's picture
Last seen: 6 hours 11 min ago
The ANR26650M1-B was reviewed by Henrik long ago, tested on his old station without fully independent cell voltage monitoring. I say this because of the July 2012 review date, not because I know it for sure so better wait for Henrik's word:
Both cells close in performance, but this newer one may have an edge.
Smile
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
vapcell Dennis
Barkuti wrote:
The ANR26650M1-B was reviewed by Henrik long ago, tested on his old station without fully independent cell voltage monitoring. I say this because of the July 2012 review date, not because I know it for sure so better wait for Henrik’s word:
Smile
You are right Thumbs Up ,can you get many M1b in your country?
