I would probably buy 20 pcs of the Osram Oslon KW CULPM1.TG (2mm² Boost HX), so 1% of the MOQ is already reached.
Based on CULNM1 sales data, I don't think there would be enough interest.
Order # L4P2066 received. Everything is supremely decent. Packaging, delivery time awards all praise.
Where can I read about the correct switching of thermal control, wire wiring, as well as setting up the driver?
Respectfully ….
I think people were anticipating the 2mm boost way more than the 1mm boost.
Why not start an interest list?
I could help if needed.
Yeah, people are conditioned for Group Buys around here. I think if an interest list were started, in a new thread, and given enough time, you could easily reach a couple thousand or more, especially considering that the Boost HX is one of the most highly anticipated emitters in recent years. I’m not surprised at all that the “lesser” version didn’t get much interest.
I’m sure I can get Vinh of Skylumen to buy a ton of them. He goes through the non boost 2mm White like a kid at a candy store.
I know I’d buy some myself. It has to be a high bin though.
Hello I would like to purchase six LUMINUS SST-20 4000K 95CRI LED (SST-20-W40H-A120) – Bare and two L4P 3XP Triple 20mm DTP (Direct Thermal Path) Copper MCPCB. I wondering if you offer a flow service to flow the leds onto the board? Thank you!!
I believe this listing is what you want (nevermind his lazy URL naming he does good soldering, lol)
Thank you!’
I corrected URL, it's not laziness, just lack of time and pretty bad web template (sometimes it auto-generates URL fine, sometimes not).
New link:
That's the problem, you can't cherry pick bins.
I just purchased two of the sst-20s with mcpcb, I forgot to ask if the 100kOhm NTC temp sensor is for one of your drivers Led4power? It’s not needed if I use a different driver and can be unsoldered?
Once the triple/quad 3030 MCPCB are released I guess you will see huge bump in sales. Just like the SST-20 it is not a very interesting led in singles as I don’t have good hosts for them. Vinh gets pretty impressive numbers with the FW3A: 3*W1 Clear Lens: 2000L, 45Kcd, 424m. No idea where he gets the 3030 triple though…
Yes, it's for LD-A4. You don't need to unsolder it if you going to use other driver.
Those are next on my DTP list.
Thank you!
Worth noting, the triple/quad board for Luxeon V (also 4040) are great and I use them with the normal Carclo optics.
They are compatible with carclo optics, but OSRAM 4040 footprint is not exactly the same as Luxeon's, so Cu DTP 4040 can be used for CULNM1, but mosX can't (central pad on them is wider).
Can you perhaps describe the beam of the Luxeon V’s under a 10507 optic? I had Luxeon V’s in my Emisar D4 and it was a floody mess. Maybe they produced a better beam under the triple optic…
