A heat resistant 7mm outer diameter circular gasket for E21A would be awesome (it should have approximately 3mm inner diameter, and the hole should be circular, as phosphorus layer on E21A is rather sensitive to mechanical stress, while gasket is rotated during assembling). Once this is completed, that would support many builds - currently no one did this for us yet.
E21A is currently the best high CRI emitter for flashlights - a bit lower powered, than SST-20 high CRI (only about max. 2A per emitter), but the offered CCT range is unmatched by concurrent offerings
Hi Simon,
Do you have or plan any flashlight able to use all of AA / NiMH / 14500 li-ion (voltage range 0.8…4.4V)?
Interested in both one and two cell variants.
Are the XHP35 drivers going to be sold at the Convoy Flashlight store in the near future? I’m guessing a 17mm board would be too small to adapt the items required for that driver?
Thanks Simon! Order placed with note yesterday. Kind of curious what this Bluish Gray is going to look like. Then I noticed a Pastel Blue on sale this weekend but the pics seemed to be the standard gray. So wondering what Pastel Blue looks like.
Also, is that you selling through Banggood? Just received 2 S2+’s and 2 S11’s. One of the S11’s shows signs of being dropped and it doesn’t work. Switched bodies around between the working one and the broken one and it’s definitely something in the head. The two wires suppling the emitter are fine so it’s something farther inside the pill but I’m not interested in going any farther.
Emailed Banggood about a refund on the broken light. So you might see that. Thanks!
I prefer memory mode. Switch on where I left it. PWM is ok if it is fast enough (S2, C8)
Strobe can stay if it is hard to initiate. E.g.: Lumintop Tool AA 2.0: click 6 times quickly to start strobe.
