Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
BTW, is the Bluish Gray actually a different color than the standard Gray Convoys come in? Thanks!
Are the XHP35 drivers going to be sold at the Convoy Flashlight store in the near future? I’m guessing a 17mm board would be too small to adapt the items required for that driver?
Hey Simon. Can you offer the M21A with a good 21700 battery? I can’t find them anywhere that ships to my country.
pity that only support LG SONY TESLA SAMSUNG 21700 (DIAMETER LESS THAN 21.5MM)
Hi Simon,
Do you have or plan any flashlight able to use all of AA / NiMH / 14500 li-ion (voltage range 0.8…4.4V)?
Interested in both one and two cell variants.
i will get AA/14500 driver with high efficiency soon ,one or two weeks
What is the most reasonable mode ?
15%off
there is no code
submit your order ,then close the payment ,and last you leave a message to change the amount
factory will produce normal gray in the next batch
22mm ,friend,17mm is too small
i will get some LG SONY SAMSUNG 21700 in stock soon
Maverick1947:Hey Simon. Can you offer the M21A with a good 21700 battery? I can’t find them anywhere that ships to my country.
Nice! Will definitely buy some.
Is the new L2 21700 XHP35 driver compatible with the original 26650 L2 design? Will it fit?
I think the answer is no. But checking anyways.
Thanks.
Hello Simon,
do you have any 3V driver with 22mm diameter and for reverse clicky?
Which adapters do you have for 22mm drivers?
andr3w:Hi Simon,
Interested in both one and two cell variants.i will get AA/14500 driver with high efficiency soon ,one or two weeks
I would be interested in such driver, if it is compatible with the T2 host, and has faster PWM than the T2.
sochi111: Simon Mao: sochi111:Simon,
I am sure you are pretty busy but I wanted to know if
you were able to fix the driver?I have tried a lot, but it has not been solved yet.
I want to introduce other firmware, such as bistro, crescendo
Thank you for getting back, :heart_eyes:
I guess this looks like a really expensive fix.Are the S2+ Colors going to be discontinued
or updated with new firmware? :cry:do you colors for other model ?
Do you mean, if I like colors for other models?
Which models do you recommend?
My favorite is S2+ and the only 18650 model in colors. C8 has some color too but same firmware issue. Let me know what do you recommend :heart_eyes:
andr3w:Hi Simon,
Moonlight, low, medium, high. No strobe of any kind. Always starts in moonlight. No PWM.
Glennac:Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
15%off
there is no code
submit your order ,then close the payment ,and last you leave a message to change the amountfactory will produce normal gray in the next batch
Thanks Simon! Order placed with note yesterday. Kind of curious what this Bluish Gray is going to look like. Then I noticed a Pastel Blue on sale this weekend but the pics seemed to be the standard gray. So wondering what Pastel Blue looks like.
Also, is that you selling through Banggood? Just received 2 S2+’s and 2 S11’s. One of the S11’s shows signs of being dropped and it doesn’t work. Switched bodies around between the working one and the broken one and it’s definitely something in the head. The two wires suppling the emitter are fine so it’s something farther inside the pill but I’m not interested in going any farther.
Emailed Banggood about a refund on the broken light. So you might see that. Thanks!
Simon Mao:i will get AA/14500 driver with high efficiency soon ,one or two weeks
What is the most reasonable mode ?Moonlight, low, medium, high. No strobe of any kind. Always starts in moonlight. No PWM.
I prefer memory mode. Switch on where I left it. PWM is ok if it is fast enough (S2, C8)
Strobe can stay if it is hard to initiate. E.g.: Lumintop Tool AA 2.0: click 6 times quickly to start strobe.
Thanks.
uh ,it’s different
Hello Simon,
Simon Mao: andr3w:Hi Simon,
ok
Simon Mao: Glennac:Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
15%off
there is no code
what’s your order number? have i adjusted the amount
