Thanks Simon! Order placed with note yesterday. Kind of curious what this Bluish Gray is going to look like. Then I noticed a Pastel Blue on sale this weekend but the pics seemed to be the standard gray. So wondering what Pastel Blue looks like.
Also, is that you selling through Banggood? Just received 2 S2+’s and 2 S11’s. One of the S11’s shows signs of being dropped and it doesn’t work. Switched bodies around between the working one and the broken one and it’s definitely something in the head. The two wires suppling the emitter are fine so it’s something farther inside the pill but I’m not interested in going any farther.
Emailed Banggood about a refund on the broken light. So you might see that. Thanks!
I prefer memory mode. Switch on where I left it. PWM is ok if it is fast enough (S2, C8)
Strobe can stay if it is hard to initiate. E.g.: Lumintop Tool AA 2.0: click 6 times quickly to start strobe.
With the S2+ and C8+ the first thing I did is to set memory mode
One thing is sure: most important is to ramp from low to high, and make hard to initiate strobe.
Anyway, is it that hard to implement a memory mode in these drivers, what the user can turn on or off? It looks like it was not a problem with the Attiny.
Since I joined BLF, there is discussion about memory/no memory, and no one will convince the other.
So yes please, mode order low->high, and option to switch memory on/off. I like the classic way to do that: after 5 seconds in lowest mode a quick off-on blink shows, then click to toggle memory on/off.
Please don’t do the blinky stuff! :sunglasses: I have changed the driver in my S2+ lamps because of that blink in low mode The “click an insane amount to go to settings” is way better I think.
Toykeepers Bistro/Biscotti buzzing after 10 clicks would be way better than that utterly annoying blink after 5s on low mode, literally everyone hates it and it’s a medieval solution.
IMO:
FF (0.5lm or less)>Low>Medium>High (looped)
Instant mode memory with no waiting for two hours for the driver to activate it
double press to go back one mode or long press to go to the first mode
optionally Biscotti style programing after 10 half presses to reverse the mode order to H>M>L>FF and to turn off or on the Mode memory.
This way everyone would be happy, it will stay muggle friendly and the implementation shouldn’t be a challenge.
Yep, Bistro UI. Strobe is hidden, memory and moonlight can be enabled/disabled, number of modes and modes order (low to high, high to low) can be changed, etc.
It’s better to have an UI that is configurable by the user than changing convoy UI each time someone request a varation that can be changed with a programmable UI.
I did not know that the blib on low mode for mode group changing was so thoroughly hated among BLF :party:
Ok Simon, please do not do that but listen to the other suggestions
