I just like to point out that I did not say that they are fake Sanyos, but my concern is that are they 'eneloops' considering it's never printed in the label of the battery itself as 'ENELOOP'. Although it says 'eneloop powered'' CHEERS !
I finally got my hands on a few 3rd generation eneloops!
They are already available in Japan for quite a while, but was waiting to come across some good deals.. but unfortunately that seems to take ages.. So I went ahead and bought it at the cheapest place I could find ;)
The fun part is that the cheapest are actually the special Chocolat tones, and not the original white ones.. I dont mind.. they look pretty sweet!
Today was a little stormy here in Tokyo, so I had to cut short my little trip to my favorite place in town, Akihabara. Anybody been there?
Here are some pics of the AAA`s
The packaging looks really good as well, and the nice thing is that all the batts are lined up very well.
as you can notice, all the cells are numbered! (like Kreisler said before, about the Glitter eneloops)
Also the production date is printed. September 2011.
3rd gen looks pretty close to the 2nd gen. 1800 times I dont really care about. Im not going to charge batteries 1800 times vs 1500 times, not much difference to me.
It’s not the mah, it’s the ability of the battery to take high drain for long periods of time and maintain 1.1v-1.2v. Most of the high powered emitters would be considered high drain when set on high 3+amps. Eneloops have been proven to be one of the best AA NiMH at taking high drain for longer periods of time, plus they are low discharge and retain their charge when not used. Even though they are 2000mah, they can take 3 & 5 amp drains for longer and hold voltage longer than many AA batteries. Some Batteries used for RC like Sub C NiMH and other “odd sized” NiMH can have up to 40 amp drain for short periods of time, so in a flashlight pulling 6 to 9 amps, they do quite well also. Most high mah NiMH batteries prove out to be not so good at high drain and they have too much voltage sag too soon.
That is my opinion only and I am not any kind of expert on anything....
It really depends on charge retention - but camera flashes draw heavy current from the cells. As Old-Lumens has said, Eneloops are good at heavy draw, other LSDs may or may not be.
For normal use in adequate light the higher nominal capacity will probably win especially if you are taking lots of pictures. I you don't use the camera regularly, it depends on self-dischage rates - which may vary. I've not tried the GP cells but if I can find them for a sensible price (i.e., less than the same number of Eneloops) I'l put some on test for a while. It will take a year or so to get final results. If the GP cells are cheaper than eneloops I'd try a set, if they cost more I'd wait till someone else tests them.
I have used eneloops (1st & 2nd gen) for about a 1.5 yrs. for my canon 7d dslr (6 aa batteries in the battery grip) more than I use the li-ion battery that came with the camera. Eneloops last longer with my camera gear imo. I also use the 2500mah exxeloops for my speedlite 430ex ii flash and have never had a problem....ever.
You can't go wrong using eneloops.
Eneloops are THE best aa/aaa nimh batteries, period.
Ive been using 2nd gen 2000mAh Eneloops in my point and shoot digicam for ~1.5y, works great! Was eating primaries like theres no tomorrow, while with Eneloops it stays up and running almost like forever, unless you do HD/FullHD recording, that eats up them faster than regular picture taking with or without flash.
Edit:
Just checked HR-3UTGB prices on ebay.com:
26$ for 4 pieces of Disney themed and 17$ shipping fee to EU.
I wonder why it takes them so long to release 3rd gen outside Japan?
I like Eneloops, but if you go looking for a bargain on them, you might end up with fakes. Be very careful. If you want to save a little money, there are other brands of LSD NiMH's that are still way better than normal NiMH's that self-discharge in a month. Definitely get LSD batteries, get Eneloops if you can afford them.
