*** NEW *** Haikelite MT40 *** Update *** 2019-06-19
28 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 48 min 3 sec ago
ACTIVE GROUPBUY MT40: http://budgetlightforum.com/node/67654
NEWS
2019-06-19: M4DM4X arranged a groupbuy here: http://budgetlightforum.com/node/67654
Another new Haikelite light. 4 x SST40, 4 × 18650, 8000 lumens, MSRP $69
Haikelite New MT40
Product characteristics:
The flashlight uses the highest grade Luminus SST-40-10W beads with a maximum brightness of 8000 lumens and a maximum range of 850 meters.
IPX8 waterproof. Super heat dissipation design, flashlight heating fast, cautious use, carefully ironing hands.
Four 18650 pointed or semi-pointed batteries are used to ensure the consistency of battery voltage.
(Note: If you insist on using flat-end batteries, you need to buckle down the anti-backlash patches at the cylinder body and tail to prevent the anti-backlash batteries from being released by yourself.)
High efficiency constant current circuit, constant brightness.
Luminance gear and endurance:
Low brightness: 200 lumen 30 hours
Mid-bright gear 1:1300 lumen 12 hours
Mid-bright gear 2: 2800 lumen 300 minutes
High brightness: 4500 lumen 180 minutes
Double-click Ultra-bright: 8000 lumen 140 minutes
Double-click on Ultra-bright Gear again: Flash
Hidden Bright Mode: 2 lumens (turn off, press switch for 2 seconds)
Temperature control defaults to 55 degrees Celsius. When the temperature of the flashlight reaches 55 degrees Celsius, it will automatically slow down to the middle brightness level. When the temperature is below 40 degrees Celsius, it will automatically slow up to the high brightness level.
Operating interface:
Click the button to boot; click Close.
Low-Medium Bright 1-Medium Bright 2-High Bright-Double Click Ultra Bright (Changing Gear by Long Press Switch,
Gear memory function, flashlight memory last closed gear)
Double-click on any gear can quickly enter the ultra-bright gear (click the gear before reply);
Ultra-bright gear, double-click again to enter explosive mode
In turn-off state, press the switch for 2 seconds to enter the light moonlight mode. In moonlight mode,
Flashlight locking: Quick double-click switch do not let go, can lock the flashlight, to prevent the flashlight discharge knapsack from opening by mistake.
It can also spin a little head power off protection.
Switch indicator:
100%~50% power: Blue light is always on
50%~9% power: blue light flickers, frequency flickers twice every 10 seconds
Less than 9% electricity: red light flashes. At the same time flashlight flash prompt, and automatically enter the ultra-low bright gear
https://www.aliexpress.com/store/product/Haikelite-New-SST40-LED-MT40-Flashlight-8000LM-Four-lamp-flashlight-8000-lumens/4692069_33040268524.html?spm=2114.12010612.8148356.1.514233f61CNcLT
(sb56637 fixed the link)
Edited by: hIKARInoob on 06/19/2019 - 18:24
acab
acab's picture
nice design, reminds me a bit of the older SRKs
Tom_182
Last seen: 6 months 1 day ago
Interesting but the link doesn’t work and I can’t find anything on AE if I try the search. How many emitters does it have? 4?
HONDARIDER
HONDARIDER's picture
I like it but I am leery of the new Haikelite’s. Had an SC04 that I bought during a GB that was DOA. It would definitely be dependent on price. Looks like 5 or 6 emitters based on the reflector (What you can see). Hopefully this is the 5000K version.
BlueSwordM
BlueSwordM's picture
Last seen: 5 days 23 hours ago
Yeah.
I really hope this uses a real quad MCPCB.
And the design looks really… generic for some reason.
Scallywag
Scallywag's picture
Last seen: 35 min 9 sec ago
Proprietary chargers are a no-go for me. Same for barrel connectors that aren't technically proprietary, but that I'd have to match voltage and current and connector size/polarity etc.
Edit: working link 4 emitters and $69
Lightbringer
Lightbringer's picture
Last seen: 1 hour 1 min ago
If I didn’t have more Q8s/DC7s than I know what to do with, I’d definitely be in for one.
I’m a little leery, though, about ironing my hands from the heat. That sounds a trifle painful.
bigtrav261
bigtrav261's picture
Last seen: 2 hours 1 min ago
mrheosuper
Last seen: 1 month 1 week ago
Interesting, but i hate adapter charger, they can use USB port instead
Forgot my pen
SKV89
Last seen: 13 hours 55 min ago
What the hell are they thinking using a proprietary charger!!? This would have been a winner if it used usb charging instead
Lightbringer
Umm, that’s a pretty big-ass charger. So imagine charging all those cells inside in 2hrs vs 12hrs or more.
I’m actually okay with it as-is, as long as it’s not some proprietary-size barrel connector.
Whups, I take that back. Pic of the charger shows it’s 2A only, so 12AH (say, 4 30Qs) would take ~6hrs from dead to topped.
mortuus
mortuus's picture
Last seen: 2 hours 20 min ago
wall charger seems weird.. usually its for lights that running 8 × 18650 or something like the bigger search lights olight,acebeam etc has.. 70$ doesnt seem that bad, it can be a hit or miss when it comes to them.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Scallywag
Scallywag's picture
Should have been USB PD.
Lightbringer
Just to clarify, that’s an actual charger, not power-brick. Ie, the charging circuitry is built into the brick. CC is limited to 2A, CV to 4.2V.
The NexTorch nylon-body 18650 light with charger has this (the 2×CR123A doesn’t). Just a plastic shell to hold the cell, NO electronix inside, just a connector for the wall-wart to supply the CC/CV friendliness to not make the cell go boom.
Only thing I’d be afraid of is if the (necessarily) direct connection to the cells from the socket would be exposed to, say, salt-water, metal shavings, etc. That would Truly Suck™.
blueb8llz
Last seen: 1 day 13 hours ago
So the switch light is turned on in standby mode correct? And does it ramp all the way to the brightest mode?
Diomedes
Diomedes's picture
What type of driver does the MT40 use?
I know it says it’s a constant current driver, but is it linear? Buck? Boost? Buck-boost?
protechteus
Last seen: 21 hours 1 min ago
hey guys,
I saw on AliExpress in Haikelite Store a MT40: “Haikelite-linterna LED CSLPM1 de 6500LM, 4 lámparas, 6500 lúmenes, noved”. What do you think about that? Is it worth any attention? It claims 1400m of range (which I can believe in, because I saw what my Convoy L21a can reach). And why the description is in spanish? Sound a little bit suspicious, but it really got my curiousity and attention. Thinking of ordering this light.
Lightbringer
AX has a totally f’ed up site. If anyone posts a link to a product on AX, and that person has his language set to spanish (or german, or tagalog, or…) and you click on it, then guess what? Now your language default is set to that, too. And sometimes it sticks and sticks and sticks and takes several attempts to reset it.
Towards the top there should be something clickable like “go to international version” which does something like switches from es.aliexpress.com or de.aliexpress.com to plain ol’ www.aliexpress.com, and maybe that’ll reset the language, but then you still might have to reset the language (and currency) to english/usd, maybe a few times.
Ironically, you might have to read spanish/german/tagalog/whatever well-enough to find that “go to international version” label.
As for the MT40, unno. Ain’t got one.
MoreLumens
MoreLumens's picture
Last seen: 5 hours 2 min ago
I checked that out and it’s just Spanish for some reason regardless your language setting. Always use English anyway.
I don’t know. Ain’t too expensive, ok beamshots, but what is the true performance then.
protechteus
I ordered this one with osram emmiters. Will see what’s this capable of Smile
Lightbringer
Unno, this one?
https://www.aliexpress.com/item/33040268524.html
Plain ol’ english here.
MoreLumens
Lightbringer wrote:
Unno, this one?
This:
https://www.aliexpress.com/item/1005002053818177.html
Lightbringer
Yep, that’s spanish all right…
Miguel_79
Last seen: 1 week 5 days ago
I really like this renewed MT40, new button, new faster driver, usb-c charging and that version with Osram LEDs for a range of about 1400 meters with 6500 lumens has to be a show, there is nothing like it on the market, and less at that price. I have the first version, with SST40 LEDs, and I highly recommend it, this new MT40, with the improvements and in its version with Osram LEDs at that price seems like a bargain.
Miguel_79
A taschelampen user has received the MT40 with the Osram, here you can see, it looks very good:
https://www.taschenlampen-forum.de/threads/haikelite-mt40-mit-cslpm1-led...
protechteus
According to my post office tracking MT40 PM1 is in my country already, so I’ll have it at least in 2 days. I’ll take some photos of beamshots and compare it to Convoy L21a with osram emmiter and to zoomie Haikelite HT35. These are the best throwers I own.
Miguel_79
Mine will take a little longer to arrive, when I have it maybe I will also put some photos comparing it with the original MT40 with SST40 5000K, with the Astrolux MF02 (XHP35 HI NW) and with the Fireflies T9R (CULNM1).
protechteus
here are some beamshots of Haikelite MT40 with osram PM1, compared to Convoy L21a with osram NM1 and Astrolux EA01 XHP50.2 (to show the intensity):
MT40 alone:
with L21a on the left:
with EA01 on the left:
and diy homemade amateur measurement of turbo stepdown time, Room temperature – 23 celcius degrees. My measurement shows that after 3 minutes it gone to somewhere in medium-high mode. I can’t say it was burging my hands, it was just a little bit hot or very warm.
start:
after 3 minutes:
