Emisar D3AA is available now
One can always find updated info thru this handy thread here ;-)
:BEER:
- SAM -
Hank, is this being done through a multi-color micro SMD LED like this one?
Wow, how does this work? Is that a TK question?
That looks awfully small for a multi led SMD.
I think the ad you posted is for 25 LED each of 5 different colors, not for a multi LED SMD.
Hank any chance for LH351D in this light ? would be nice have a multi emitter light with that…
OMG
That’s a deal breaker for me.
Wow, it looks fantastic!
I don’t think it’s quite a deal breaker for me, but it’s certainly a reason to keep using my FW3A. It’s the primary reason I keep using my FW3A instead of my D4, even slightly moreso than the fact it runs Anduril.
On the bright side, with Anduril on the new D4 I should be able to cap the ramp at something reasonable like 300 lumens to limit how much power I fritter away. The new option to make it always switch on at any desired level (such as max regulated) will be really useful too.
Don’t worry, the 3-channel driver is nice but also overrated. Sure it is a nice thought to have it in your light, but the slight efficiency gain you get in medium modes will not be noticable in your runtimes.
I seemed to notice that my FW3A goes for longer at the maximum regulated ~800lm level than my D4 at the same sort of brightness. Is this most likely because I just keep overshooting and ending up with 1000lm+?
Anduril will surely make it a lot easier to know how much output we’re getting. So glad it’s now included on Emisar’s newer flashlights.
Are external dimensions the same?
I think that magnet addition would increase the length (even for those who don’t use it) which would be a small step back…
Hank mentioned 3mm extra of the tailcap because of the magnet, so I guess overall length is 3mm extra.
I skimmed through the thread too quickly to notice. Thanks djozz!
I wonder if V1 tailcaps are compatible with V2 tubes…
Wil the Ramping IOS V2 be there as a optional choice? Not everyone likes Anduril.
Im soo interested.Cant hardly wait.
That is a good question, though from my experience I have found Anduril to operate just like Ramping IOS V2 if you only use the relevant button presses.
I have found the simple shortcut to directly ramp down instead of having to guess the ramp direction to be an incredibly useful addition in Anduril however.
Has it got reverse battery protection now ?
I’m going broke before the end of the year… :person_facepalming: :money_mouth_face:
I compared both my D4 and FW3A at step 130 which is full regulation for the FW3A. My D4 stepped down 2 minutes later than the FW3A with the same thermal config. (the FW3A has a slightly newer Anduril build though)
I guess more thermal mass and running the emitters in a more efficient zone has something to do with it. D4 is SST20, FW3A is XP-L HI, so I expected the FW3A to actually go longer if not near exactly the same.
I really need to crack open my D1 and flash it. RampingOS isnt bad, but I would like most of my lights to be consistent.
