【convoy】H4 and B35AM options are updated
I ask because there is a slot on the S21A for one (I think?) and I haven’t seen a specific S21A clip on Simon’s Ali shop listings.
I like 2×AA lights, I’m waiting for a Jaxman M2 at the moment, but I’d be interested in a Convoy S2+ style 2×AA tube light as well :slight_smile:
I like long 3×AA lights too, I’d buy several 3×AA tubes for my Convoy S2+ lights and just use the Li-Ion driver :smiling_imp:
not suitable
Same as in biscotti firmware. Only here is the first option.
Config mode
To enter config mode, quickly tap a bunch of times until the light stops lighting up. It should be 16+ times. Then it’ll scroll through the options:
1. Memory toggle. Tap during the “buzz” to turn memory on or off.
2. Thermal calibration. Tap during the “buzz” to enter thermal
calibration mode.
  • Light turns on at a low level: Tap now to set default temperature
    limit. Otherwise, wait.
  • Light goes to full brightness: Tap at any time to set temperature
    limit to the current temperature. Basically, wait until it feels
    hot, then tap.
So, to set a temperature limit:
- Tap 16+ times.
- Wait for the light to blink twice.
- Tap during the “buzz”.
  • Wait until the light feels hot, then click to turn it off.
I came here to take a look at the titanium AAA Convoy sample but I don’t see it…
Check the first post :wink:
Pics are in OP
Thank you!
I see a twisty keychain…nice. :slight_smile:
I don’t like the patina-style anodization but nevertheless I’m very interested. :slight_smile:
That 3x SST-20 light looks great!
Will optics fit in that light? I’m curious to see the beam pattern with that reflector.
Does it use a 20mm triple MCPCB? I guess the driver is 22mm and the battery is 21700 (not 21.7 700 lol)
Reverse clicky switch, right?
25mm PCB ,
carclo len doesnt fit .
i have design another host and PCB board for carclo lens ,
driver 22mm,it’s 7135*14 (5320mA) inside.
21.5mm inner diameter ,so some batteries are not suitable ,
i will add links of LG and Tesla 21700 (4800-5000mAH) in my store tomorrow
and it’s reverse switch
uhmmmm,.i tap 16+ times, but dont work……embarrassing…
i will try attiny 25V later
Simon,
Are you going to list flashlight hosts with batteries as well? For the custom modders you know. If you can ship a light with a battery you can probably ship a host with a battery too…
I would definitely buy a few of those combos.
Just for reference, I also remember flashing crescendo in a BLF A6 driver (attiny13) and no matter the clicks, I couldn’t get to the config menu.
At the time I thought that my driver was bad so I flashed back to the original firmware, but now I am starting to see a pattern :slight_smile:
AFAIK the Cresendo firmware made for Attiny13A is a slimmed down version of the one made for Attiny25. I don’t think the Attiny13A version has those fancy blinkies, memory and the option to toggle memory on/off.
To be honest, I am currently taking a look at Cresendo’s code and the only notable difference between ATTINY 13 & 25 is the amount of brightness levels that each mcu support.
@Simon Mao, maybe you can experiment with defining a different driver type (NANJG, FET_7135, TRIPLEDOWN) depending the driver you are using.
That AAA Ti light looks fantastic.
Hum, the AAA light looks great :wink: Waiting for the AA version as well :wink:
+1 - any idea when it will be for sale? Likewise the 20 triple.
The complete Crescendo UI code is too large to fit onto the memory space in an ATTiny 13, so TK created an condensed version for the ATTiny 13 and unfortunately the space used for the Config Menu and hence Memory Toggle were dropped.
If one spends some time whittling through the Crescendo source code, it should be possible to either set Memory On permanantly w/o toggle ability and/or trade some other features (e.g. blinkies, battery check, ramp smoothness, etc.) to restore Memory mode… I was successful getting memory to work on two ATTiny 13 based drivers.
Is there a plan for a clip?
