Will optics fit in that light? I’m curious to see the beam pattern with that reflector.
Does it use a 20mm triple MCPCB? I guess the driver is 22mm and the battery is 21700 (not 21.7 700 lol)
Reverse clicky switch, right?
25mm PCB ,
carclo len doesnt fit .
i have design another host and PCB board for carclo lens ,
driver 22mm,it’s 7135*14 (5320mA) inside.
21.5mm inner diameter ,so some batteries are not suitable ,
i will add links of LG and Tesla 21700 (4800-5000mAH) in my store tomorrow
Are you going to list flashlight hosts with batteries as well? For the custom modders you know. If you can ship a light with a battery you can probably ship a host with a battery too…
Just for reference, I also remember flashing crescendo in a BLF A6 driver (attiny13) and no matter the clicks, I couldn’t get to the config menu.
At the time I thought that my driver was bad so I flashed back to the original firmware, but now I am starting to see a pattern
AFAIK the Cresendo firmware made for Attiny13A is a slimmed down version of the one made for Attiny25. I don’t think the Attiny13A version has those fancy blinkies, memory and the option to toggle memory on/off.
To be honest, I am currently taking a look at Cresendo’s code and the only notable difference between ATTINY 13 & 25 is the amount of brightness levels that each mcu support.
@Simon Mao, maybe you can experiment with defining a different driver type (NANJG, FET_7135, TRIPLEDOWN) depending the driver you are using.
The complete Crescendo UI code is too large to fit onto the memory space in an ATTiny 13, so TK created an condensed version for the ATTiny 13 and unfortunately the space used for the Config Menu and hence Memory Toggle were dropped.
If one spends some time whittling through the Crescendo source code, it should be possible to either set Memory On permanantly w/o toggle ability and/or trade some other features (e.g. blinkies, battery check, ramp smoothness, etc.) to restore Memory mode… I was successful getting memory to work on two ATTiny 13 based drivers.
