Well, this may be a therapeutical flashlight after all ! I may need it
Agreed. I like most of what I see on that light, but I have a box full of lights waiting for me to get around to replacing their cool white LEDs. I don’t need to add another light to that box.
M4D M4X:new flashlight on the way!
Imalent DM70
4500 lumen from a boost driver? Hmmm…
Since most max out at maybe 3500, I’m quite skeptical.
DN70 reaches 3800 Lumen. Its a similar Watt-region with the “new” XHP70.2. So its realistic.
JasonWW: M4D M4X:new flashlight on the way!
Imalent DM70
Since most max out at maybe 3500, I’m quite skeptical.DN70 reaches 3800 Lumen. Its a similar Watt-region with the “new” XHP70.2. So its realistic.
Where did anyone measure 3800 from a DN70?
Wieselflinkpro: JasonWW: M4D M4X:new flashlight on the way!
Imalent DM70
I in my Sphere. I hope its good calibrated, compared to some other spheres I got similar readings with some identical flashlights and other readings with the same flashlight model.
I think the reviews on the DN70 maxed out around 3300 lumen. Most 26650 70.2 lights exaggerate their output. Also, 3800 to 4500 lumen is a very big jump for a boost driver.
Hello my dear friends!
Today i present you 3 new deals:
-> my links take you to the shop for more Info
-> use the forms to participate or just check my dealslist
JETBEAM JET-KO02
XHP35 1800Lumens 6Modes
USB Charging 21700 EDC Flashlight
Specifications:
Emitter Type: XHP35
Peak Beam Intensity: 18225cd
Max Output: 1800Lumens
Range: 270m
Mode: Turbo, High, Middle, Low, Eco, Strobe
Lumens: 1800LM, 1060LM, 360LM, 80LM, 12LM, 1800LM
Runtime: 1h55min, 2h, 6h45min, 27h, 140h, /
Battery Configurations: 1 x 21700 Battery (Included)
Impact Resistant 2m
Waterproof: IPX-8 Waterproof
Weight: 88g
Size: 130.3mm x 27.1mm x 27.8mm (Length x Diameter x Tail Diameter)
Haikelite MT40 for $ 45.99
SST-40 7Modes 8000Lumens
High Brightness 18650 Flashlight
Specifications:
Emitter Type: SST-40
Light temperature: 5000-6500K
Max Output: 8000Lumens
Mode: Low, MediumⅠ, Medium Ⅱ, High, Ultra High, Strobe, Ultra Low
Lumens: 200LM, 1300LM, 2800LM. 4500LM, 8000LM, / , 2LM
Runtime: 30h, 12h, 300mins. 180mins, 140mins,/ , /
Battery Configurations: 4 x 18650 Battery (Not included)
Weight: 469g
Astrolux FT03 for $34.99
XHP50.2 4300lm 735m
NarsilM v1.3 USB-C Rechargeable 2A 26650 21700 18650 LED Flashlight
Specification & Features:
Emitter: one LED, cool white or neutral white , mounted on copper DTP MCPCB
Color temperature: cool white: 6000-6500K; natural white: 5700K
Flux: 4300 lumen
Intensity: 133,000cd
Range: 735 meters
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
use my CODE: MFT03X to lower the price to: US$ 34.99
Hello my dear friend!
Have you been lurking around a flashlight from banggood and been waiting for a deal to come available for long time?
So here is the chance to get a nicer price:
GET 12% OFF the whole flashlight section with the
CODE: BGTORCH
do not forget to search my page for a higher discout!
- look into M4D M4X deals if a special deal is listed
- check if your flashlight can be used with my personal 20-32% OFF code in this collection
- use the searchfield in upper right corner for other
Can you renew the Convoy L2 sand / silver code at banggood?
i ask them !
Time to say goodby and find a verdict for the acebeam X70 with its blinding 60000 Lumens.
https://youtu.be/OLPdPQUQmS4 (stills)
https://youtu.be/rJ_oy5fZ5PQ [video from different angles)
and on my regular spot
https://youtu.be/s8tFIgf-Mf4
the folomov C2 has been since its available (and still is) cheaper in my list ;)
#avoidtheclickbait
didn’t you have a code for this light for Amazon at one time? If so, is that still available or not? Thanks.
yes - but that's expired.
I can ask if I get a new if you want.
thank you yes Martin
she said it expired June, 13
when a new one is available I get the info
hallo.Imalent DM70 is also with neutral white led or just cw?thanks
i ask the owner
Hi Martin,
my Uni-T clamp meter stopped working (does not read currents anymore, or at random) so I wanted to buy a new one, but your BG code for the UNI-T UT210E gives “expired”. Is it possible to arrange a new code?
Cheers, Jos
