【convoy】H4 and B35AM options are updated
Hum, the AAA light looks great :wink: Waiting for the AA version as well :wink:
+1 - any idea when it will be for sale? Likewise the 20 triple.
The complete Crescendo UI code is too large to fit onto the memory space in an ATTiny 13, so TK created an condensed version for the ATTiny 13 and unfortunately the space used for the Config Menu and hence Memory Toggle were dropped.
If one spends some time whittling through the Crescendo source code, it should be possible to either set Memory On permanantly w/o toggle ability and/or trade some other features (e.g. blinkies, battery check, ramp smoothness, etc.) to restore Memory mode… I was successful getting memory to work on two ATTiny 13 based drivers.
Is there a plan for a clip?
The titanium alloy light is gorgeous, what’s the driver size? LED? UI?
Reylight has an AA/14500 driver that goes Moon - Low - Med - High. With 8 taps to disable/enable memory. I wish they sold it separately somewhere.
A small Convoy light with an AA/14500 driver with low to high mode order and the ability to turn memory on and off, and very fast or no PWM would be great.
yes, but it’s not convenient to add link in my store,
if you have this requirement ,you can PM me ,and do transaction via paypal
stainless steel clip is suitable ,but the screws are little short
Simon, do you have plans to create a flashlight with 3*XHP50.2 or 4*XHP50.2?
absolutely agree
That need to be a huge light. even one XHP50.2 generates a lot heat. A triple neet to have at least L6 size head and need to run on 3-4 18650s or 21700.
50.2 3v
Why is that change anything? I have one in an FT03 and in an L6 and one piece makes them hot. It draws 14A.
In real use, turbo mode is rarely needed. The advantage is that a with 3*XHP50.2 or 4*XHP50.2 flashlight will be able to produce up to ~ 2000-2500 Lm for a long time without triggering the thermal control.
My friend!
First of all: Attiny 13 doesn’t have internal thermal sensor.
On the other hand Crescendo doesn’t support any external thermal sensors.
Attiny 25 has internal thermal sensor. :+1:
For Attiny 25 you must use this version of Crescendo: crescendo-25.hex
But the best option is to talk to TK. :wink:
P.S. I want to say I really respect Simon. He always sent me various small things for free.
He just said: “Order something and I will add to the order what you need for free.”
Wide-hearted man. Thank you friend!
Today I checked Crescendo for attiny13 and nanjg_layout (single channel). It is indeed too big. You must remove all blinky modes and memory.
Then I checked for attiny25 and fet_7135 layout (dual channel). On the default settings everything fits. There is even thermal regulation.
It seems that you have to use attiny25.
Those are nice looking fins. Can’t wait to see the 3 and 4 emitter Carclo TIR variant of the flashlight head :slight_smile:
Is this design with a 26650 battery or a 21700?
Honestly, I prefer a triple reflector, especially if it uses an OP one.
Reflectors are more efficient than TIRs, so that’s a good thing.
On the other hand, TIRs have more ‘creamy’ beam, that is why they are also desirable.
But as you said, this design would be even better with an OP reflector (fine/mild texture).
Even another thing, that multi emitter reflector flashlights are almost always with small reflectors for each emitter. I would also happily take one with e.g. 6 or 7 emitters, and at least 35-40 mm diameter reflector for each emitter in the flashlight head (with nearly no or just slight overlapping).
yes, but it needs several months
