Reylight has an AA/14500 driver that goes Moon - Low - Med - High. With 8 taps to disable/enable memory. I wish they sold it separately somewhere.
A small Convoy light with an AA/14500 driver with low to high mode order and the ability to turn memory on and off, and very fast or no PWM would be great.
That need to be a huge light. even one XHP50.2 generates a lot heat. A triple neet to have at least L6 size head and need to run on 3-4 18650s or 21700.
In real use, turbo mode is rarely needed. The advantage is that a with 3*XHP50.2 or 4*XHP50.2 flashlight will be able to produce up to ~ 2000-2500 Lm for a long time without triggering the thermal control.
P.S. I want to say I really respect Simon. He always sent me various small things for free.
He just said: “Order something and I will add to the order what you need for free.”
Today I checked Crescendo for attiny13 and nanjg_layout (single channel). It is indeed too big. You must remove all blinky modes and memory.
Then I checked for attiny25 and fet_7135 layout (dual channel). On the default settings everything fits. There is even thermal regulation.
It seems that you have to use attiny25.
On the other hand, TIRs have more ‘creamy’ beam, that is why they are also desirable.
But as you said, this design would be even better with an OP reflector (fine/mild texture).
Even another thing, that multi emitter reflector flashlights are almost always with small reflectors for each emitter. I would also happily take one with e.g. 6 or 7 emitters, and at least 35-40 mm diameter reflector for each emitter in the flashlight head (with nearly no or just slight overlapping).
