(prototype) the GT Mini
I’m not sure it’s all about the switch. There are few strange experiences:
  • In Modes from standby I click once. Moonlight comes up, switch flashes three times and the light goes off. Sometimes it does this way, sometimes it turns on.
  • In Modes from standby I triple click - seems like nothing happened. Looking on the led, it’s in moonlight and before I could turn away it burns my eyes.
So delayed, sudden and surprising answers coming from the light in Modes.
The D shaped boot activation pad is catching on the side of the driver, delivering an unusual pressure that may stay applied for a short time after you click resulting in the driver “thinking” a different action was required from what you intended. The boot needs to be rotated slightly so that the flat top side of the D shape can clear the driver, you should have no problems after that.
You can probably use a sharp wood chisel to slightly raise the retaining ring, bump the chisel in slightly from each side to give some wiggle room for the boot, then align it. Try it in action and see if it is fixed, if so, tap the retaining ring back in. :wink:
Thank you Dale, perhaps I’ll do it once. Not in the next two weeks for sure.
Are there any aftermarket boots which fit?
Having switch issues with my GT Mini.
Any solutions?
I not sure I could replace it.
Don't want to mess up a light being ham fisted.
Spent a life working on cars but this switch is teeny.
1. What is it doing ?
2. Where did you buy it??
3. How long have you had it???
  1. Does not register every click. (Sometimes you can click it 4 times it does nothing, no matter wahat mode it is in, even momentary)
  2. Bangggood
  3. Since Sept 2018
Ok, then your issue is same that me and some others had, button does not register clicks etc… but weird did u use the light and no issues since sept 2018 and suddenly problems? My issue started probably just a few weeks after i got mine from Neal during group buy hardly used, i got a new head replacement which i requested. Maybe try request it to banggood also but i dont know how they will deal with this problem now?
Well, rotate the switch cover slightly.
It’ll fix the problem instantly.
Thanks Guys.
I will try Banggood but as you say doubt they will help.
How do you twist switch cover? Just tried seems like it will rip doubt its glued.
You just take some pliers, and remove it gently.
It should pop right out.
This is what I did on my GT Mini anyway.
Yep that worked.
I ripped it a bit but all ok.
Thanks All.
Only started a few days ago. I dont edc it but get used regularly.
Ok, that ’ sounds familiar. Bought it in September from Banggood… they might or might not help.
Rotating the switch might fix it. HERE is a post that gives some details & pics about that.
This is normal switch orientation…
This is the underside of the switch.
Ooops, looks like I should have read to the end before posting the above. :smiley:
Did rotating the switch fix it??
Yes been playing with it for half hour
Did slightly rip the cover, but its never looked smiled face, just smiley mouth.
Could not get the retaining ring out either.
But it works.
@ fluke
If you pulled the rubber cover out completely you should be able to take a small flathead screwdriver & slowly pry the retaining ring up by going around it from the inside & gently lifting as you go until it loosens & comes out.
Glad it’s working.
Tried prying, but gave up.
Ok, I understand. Thanks for the reply. :beer:
You can also use a flat blade screw driver and try twisting around the bottom edge like this.
This way your only lifting. If you pry or lever the screwdriver your pushing down on the opposite side of the ring which defeats the purpose.
You’ll probably have to go in a circle or back and forth opposite sides lifting just a small amount each time.
