【convoy】GT FC40 1800-2000K R9050
6466 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 1 day 6 hours ago
KevinZA1988 wrote:
That 3x SST-20 light looks great!
Will optics fit in that light? I’m curious to see the beam pattern with that reflector.
Does it use a 20mm triple MCPCB? I guess the driver is 22mm and the battery is 21700 (not 21.7 700 lol)
Reverse clicky switch, right?
25mm PCB ,
carclo len doesnt fit .
i have design another host and PCB board for carclo lens ,
driver 22mm,it’s 7135*14 (5320mA) inside.
21.5mm inner diameter ,so some batteries are not suitable ,
i will add links of LG and Tesla 21700 (4800-5000mAH) in my store tomorrow
and it’s reverse switch
Simon Mao
Simon Mao's picture
Chatika vas Paus wrote:
Simon Mao wrote:
i have a problem with Crescendo UI , there is no memory function , is it because of attiny 13?
Same as in biscotti firmware. Only here is the first option.
Config mode
To enter config mode, quickly tap a bunch of times until the light stops lighting up. It should be 16+ times. Then it’ll scroll through the options:
1. Memory toggle. Tap during the “buzz” to turn memory on or off.
2. Thermal calibration. Tap during the “buzz” to enter thermal calibration mode. – Light turns on at a low level: Tap now to set default temperature limit. Otherwise, wait. – Light goes to full brightness: Tap at any time to set temperature limit to the current temperature. Basically, wait until it feels hot, then tap.
So, to set a temperature limit:
- Tap 16+ times.
- Wait for the light to blink twice.
- Tap during the “buzz”.
- Wait until the light feels hot, then click to turn it off.
uhmmmm,.i tap 16+ times, but dont work…..embarrassing…
i will try attiny 25V later
KevinZA1988
KevinZA1988's picture
Last seen: 2 months 4 weeks ago
Simon,
Are you going to list flashlight hosts with batteries as well? For the custom modders you know. If you can ship a light with a battery you can probably ship a host with a battery too…
I would definitely buy a few of those combos.
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
bilakos10
bilakos10's picture
Last seen: 2 hours 36 min ago
Config mode
- Tap 16+ times.
Just for reference, I also remember flashing crescendo in a BLF A6 driver (attiny13) and no matter the clicks, I couldn’t get to the config menu.
At the time I thought that my driver was bad so I flashed back to the original firmware, but now I am starting to see a pattern Smile
ControlTheController
ControlTheController's picture
AFAIK the Cresendo firmware made for Attiny13A is a slimmed down version of the one made for Attiny25. I don’t think the Attiny13A version has those fancy blinkies, memory and the option to toggle memory on/off.
Umm, I want lumens but I want CRI too...
bilakos10
bilakos10's picture
To be honest, I am currently taking a look at Cresendo’s code and the only notable difference between ATTINY 13 & 25 is the amount of brightness levels that each mcu support.
@Simon Mao, maybe you can experiment with defining a different driver type (NANJG, FET_7135, TRIPLEDOWN) depending the driver you are using.
Scallywag
Scallywag's picture
Last seen: 9 hours 4 min ago
That AAA Ti light looks fantastic.
MascaratumB
MascaratumB's picture
Last seen: 4 hours 5 min ago
Hum, the AAA light looks great Wink Waiting for the AA version as well Wink
Rusty
Rusty's picture
Last seen: 20 hours 47 min ago
+1 – any idea when it will be for sale? Likewise the 20 triple.
pc_light
pc_light's picture
Last seen: 7 hours 18 min ago
The complete Crescendo UI code is too large to fit onto the memory space in an ATTiny 13, so TK created an condensed version for the ATTiny 13 and unfortunately the space used for the Config Menu and hence Memory Toggle were dropped.
If one spends some time whittling through the Crescendo source code, it should be possible to either set Memory On permanantly w/o toggle ability and/or trade some other features (e.g. blinkies, battery check, ramp smoothness, etc.) to restore Memory mode.. I was successful getting memory to work on two ATTiny 13 based drivers.
Seeking the light.
Umpi2000
Last seen: 1 hour 37 min ago
Simon Mao wrote:
Umpi2000 wrote:
Does anyone know if the S2+ clip will fit the S21 correctly?
not suitable
Is there a plan for a clip?
Umpi2000
The titanium alloy light is gorgeous, what’s the driver size? LED? UI?
jasontheguitarist
Last seen: 1 hour 15 min ago
Reylight has an AA/14500 driver that goes Moon – Low – Med – High. With 8 taps to disable/enable memory. I wish they sold it separately somewhere.
A small Convoy light with an AA/14500 driver with low to high mode order and the ability to turn memory on and off, and very fast or no PWM would be great.
Simon Mao
Simon Mao's picture
KevinZA1988 wrote:
Simon,
yes, but it’s not convenient to add link in my store,
if you have this requirement ,you can PM me ,and do transaction via paypal
Simon Mao
Simon Mao's picture
Umpi2000 wrote:
Simon Mao wrote:
not suitable
stainless steel clip is suitable ,but the screws are little short
Di_Joker
Di_Joker's picture
Last seen: 5 hours 47 min ago
Simon Mao wrote:
Simon, do you have plans to create a flashlight with 3*XHP50.2 or 4*XHP50.2?
Sorry for my poor english.
delete
Di_Joker wrote:
Simon Mao wrote:
Simon, do you have plans to create a flashlight for 3*XHP50.2 or 4*XHP50.2?
absolutely agree
ZozzV6
ZozzV6's picture
Last seen: 3 months 4 weeks ago
delete wrote:
Di_Joker wrote:
absolutely agree
That need to be a huge light. even one XHP50.2 generates a lot heat. A triple neet to have at least L6 size head and need to run on 3-4 18650s or 21700.
delete
ZozzV6 wrote:
delete wrote:
Di_Joker wrote:
absolutely agree
50.2 3v
ZozzV6
ZozzV6's picture
delete wrote:
ZozzV6 wrote:
delete wrote:
Di_Joker wrote:
absolutely agree
50.2 3v
Why is that change anything? I have one in an FT03 and in an L6 and one piece makes them hot. It draws 14A.
Di_Joker
Di_Joker's picture
ZozzV6 wrote:
delete wrote:
Di_Joker wrote:
absolutely agree
In real use, turbo mode is rarely needed. The advantage is that a with 3*XHP50.2 or 4*XHP50.2 flashlight will be able to produce up to ~ 2000-2500 Lm for a long time without triggering the thermal control.
sob4ak
sob4ak's picture
Last seen: 2 years 6 months ago
My friend!
First of all: Attiny 13 doesn’t have internal thermal sensor.
On the other hand Crescendo doesn’t support any external thermal sensors.
Attiny 25 has internal thermal sensor. Thumbs Up
For Attiny 25 you must use this version of Crescendo: crescendo-25.hex
But the best option is to talk to TK. Wink
P.S. I want to say I really respect Simon. He always sent me various small things for free.
He just said: “Order something and I will add to the order what you need for free.”
Wide-hearted man. Thank you friend!
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 1 hour 11 min ago
Config mode
- Tap 16+ times.
Today I checked Crescendo for attiny13 and nanjg_layout (single channel). It is indeed too big. You must remove all blinky modes and memory.
Then I checked for attiny25 and fet_7135 layout (dual channel). On the default settings everything fits. There is even thermal regulation.
It seems that you have to use attiny25.
adam7027
Last seen: 13 hours 9 min ago
Simon Mao wrote:
2019/6/19
following are the photos of flashlight with 3*sst20 & Crescendo and the titanium alloy AAA flashlight
Those are nice looking fins. Can’t wait to see the 3 and 4 emitter Carclo TIR variant of the flashlight head Smile
Is this design with a 26650 battery or a 21700?
BlueSwordM
BlueSwordM's picture
Last seen: 17 hours 28 min ago
Honestly, I prefer a triple reflector, especially if it uses an OP one.
Reflectors are more efficient than TIRs, so that’s a good thing.
adam7027
On the other hand, TIRs have more ‘creamy’ beam, that is why they are also desirable.
But as you said, this design would be even better with an OP reflector (fine/mild texture).
Even another thing, that multi emitter reflector flashlights are almost always with small reflectors for each emitter. I would also happily take one with e.g. 6 or 7 emitters, and at least 35-40 mm diameter reflector for each emitter in the flashlight head (with nearly no or just slight overlapping).
Simon Mao
Simon Mao's picture
Di_Joker wrote:
yes, but it needs several months
Simon Mao
Simon Mao's picture
adam7027 wrote:
Simon Mao wrote:
2019/6/19
21700 Smile
Simon Mao
Simon Mao's picture
sob4ak wrote:
My friend!
thanks for you HEX file Thumbs Up
Simon Mao
Simon Mao's picture
i tried OP and SMO triple reflector ,the beam of SMO is better Big Smile
