Hi Barry, I have some suggestions about your recent flashlight launches (e.g. SD05, SP70) that use Sofirn's UI instead of Andúril/NarsilM.
Maybe you can forward and discuss them with your engineering team? I'm sure these updates will not be too hard to implement but they will certainly make your successful flashlights even more successful and more popular.
Please remove timer-triggered stepdowns from future drivers/flashlights. I do not see any reason to have both thermal and timed stepdowns at the same time.
Please allow a user defined choice of ATR thresholds (e.g. 45°C, 55°C, 65°C) just like HaikeLite did with their SC26
Thermal protection setting can be accessed by 10xclicks:
The light flashes once => turn it off to select 45 degree step-down temperature
The light flashes twice => turn it off to select 55 degree step-down temperature
The light flashed 3 times => turn it off to select 65 degree step-down temperature
Eventually, Sofirn can make 45°C as the default setting that will allow a safe and comfortable usage while flashoholics, experts, evangelists and enthusiasts can raise the threshold to a higher value they deem more reasonable, maxing out the full potential of Sofirn's powerhouse flashlights like SP70, Q8 and SP36. There will not be any trade off for customers who prefer a simpler UI than Andúril or NarsilM as they still get the chance to push their flashlights (and skin :-D ) to their very limits.
I’d like to see a single emitter light like the SP32A V2 but with Anduril. Seems like it’d just need a driver upgrade.
Sofirn’s stock UI’s usually keep me from buying their lights. I just got the SP36 BLF Anduril and it’s awesome. I even defeated sofirn’s favorite glue to get the driver out and flash the latest firmware build.
Fitting an E21A in a commercial flashlight requires some skilful designing: you can not use a centering piece because the led is small, shallow and fragile, the force of the reflector via the centerpiece easily kills the led. And still the small E21A requires precise centering, even in a reflector as small as in the SC31. I have not seen a commercial solution for that yet.
Nice little flashlight Appparently a centering piece works with that small reflector, but even there I wonder what mechanical stress the led experiences?
Tint-mixed quad E21A can act as a very rosy 5050 emitter. And a quite powerful one, though working around the hole in the middle makes it a flooder-only option.
Lov Vf which is a mixed blessing really
Very low profile - in a light designed for it it saves almost 1 mm compared to XP-L HI and over 2 mm compared to XP-L HD. As long as you can focus your optics properly.
Question - is the “All Products” tab in the AliExpress app on the Sofirn store just showing everything in order of newest product? So any time anything new is added, it’ll be immediately visible there?
(If not, I think it’d be a great idea - very fast way to see what’s new and interesting)
In terms of a summarized feedback on Sofirn's C8G I have some suggestions for a C8G V2.0:
Please increase the current from 1.7A to 2.2A to drive the XHP35 HI to its sweet spot. You should easily reach actual 2,000 OTF lumens.
Please reinstate the C8F user interface, i.e. standby functionality by side switch.
Please increase the thermal threshold for stepdown to 60-65°C as 50°C is way too low to ensure proper usage of turbo mode. Or even better: Please think about implementing a user defined threshold like HaikeLite did with the SC26 (please click here to see more details: https://budgetlightforum.com/t/-/54158/1011).
Please improve the ramping mode as it does not appear linear to the human eye when ramping up.
The sample I received from Sofirn has also some factory faults like an offcentered LED and a fogged up glas lens (inner side affected). I know this is not the usual case with Sofirn's good quality but in terms of quality assurance I wanted to let you know about it anyway.
