A lot of work here and while it is not perfect(crappy host) it looks fairly well…
330 KCD with good spg2s42b are results I got for this light and equivalent in lux performance to B158. So your build indicates that we can expect 400+ kcd results in B158 host as well.
I really don’t know why some of you guys use soapy water for reflector cleaning? Yes I saw that is recommended several times on cpf and blf…
Anyway I would not recommend that to anyone. I would recommend LCD screen cleaning fluid and super fine microfiber cloth… It works equally well for aspheric glass lens cleaning as well.
If reflector has micro aluminum particles inside before applying lcd fluid blow the particles out with air compressor or compressed air.
Lcd cleaning fluids usually have microfiber cloth in package… Don’t use that one cause it is to rough… Leave that one for your LCD monitors…
For reflector use Super fine microfiber cloth for DSLR camera glass/LCD screen cleaning in two steps:
Spritz gently reflector/wipe with one superfine microfiber cloth and after that do another step(but without spritzing just wiping after job you done in first step) with second dry superfine microfiber cloth and it will be shinny without any flecks.
That clothes can be reused again when necessary if it will be washed in laundry machine.
I didn’t have the time or the opportunity to test my Convoy S2 with the OSRAM KW CSLNM1.TG (1mm2) White Flat + SMO reflector before. This weekend I tried it and made some night shots comparing it with another “similar” tube flashlight, a Convoy S2+ with XPL-HI U6-3A and SMO reflector.
My S2 has been shown above, so it needs no further consideration.
I must say one thing: I am really impressed with what this LED can to even in a small SMO reflector and small light! Really impressed!!! I reached real illumination at about 400m!!! With the specs of this little light and reflector I believe it is something, right? (yeah you guys that use big reflectors will say this is an ant dimension, but I still like it )
S2+ on the left >>> S2 with Osram on the right (it will be the same scheme in the sequence to follow, always with the S2 on the right)
I have a Convoy M1 build with 1mm² CSLNM1.TG nearly finished, with linear driver set at “5A” (one of the newer SST-40 drivers from Simon modified with 8mΩ sense resistor: R010 + R050 + R200). Just need to bypass the switch and solder the driver, will say something later.
I finally threw a CULNM1 in my Jaxman Z1 (you know, with the nice glass lens). It's running off 13x AMC7135, so a nominal 4.94A. I might get up the nerve to reflow another one or two on there, but maybe not. I don't have a good idea for how well the Z1 handles the heat, and I roasted the CSLPM1 I had in it first. That was probably because I had something on the LED that burned up, but I'm not sure.
Anyway, it's my first aspheric, it's a glorious gosh darned pencil beam and it's just hilarious. I haven't been out at night with it yet (I finished the mod after 11pm Friday and had a busy weekend), and I'm sure my stock MF02 outthrows it, but it's my new favorite thrower. It's so damned small it will fit in a jacket pocket, especially when twisted down to flood mode. Jaxman sent a lens cover with it even, which I actually use. And just for fun, I ended up having to use a black, reamed-out 3535 centering ring for the 4040 footprint, so it projects a nice donut image of the centering ring around the square die image.
Even if not that important, yes. I carefully glued a 3535 gasket around the emitter, one which I had previously lapped to reduce its height from 0.8mm down to 0.6 or 0.5mm. The reflector sits quite close to the solder pads. I had to dismiss my first attempts, where I left the gasket at just 0.2 - 0.3mm and the reflector wouldn't seat properly due to it landing over the pad wires. O:)
I think that with a small reflector, it is indeed impressive. The beam is not straight all the time as it has a slight opening, but it makes possible to have a tube light (eventually in a 18350 version) as a “true” pocket thrower :partying_face:
Took some quick ceilingbounce measurements, got very close to 100Kcd for my M1. I don't know how accurate is my smartphone luxmeter. I have a Sofirn C01S in case anyone wants to help getting some comparative figures. Will measure again with the help of a friend in a day or two.
M1 speaking, adjusted my homemade setup and measured again: 101.5Kcd peak and ≈97Kcd at 30s.
I really don't know how the ceilingbounce application works 30s warning sound wise. I was hoping for the 30s alarm to reset upon pressing “reset” but it doesn't seems to.
I think this is about what is to be expected from such host, doesn't it? Its reflector seems to be about half of the surface of a C8.
Will this led provide any benefits on a reflector like these - in terms of throw @ 2 or 3 amps ? or i’m better off going with xpl-hi instead ? these are motorcycle auxiliary spot lights and i want to increase throw with making the beam more narrow.
above one is @3 amps
^ this one is @2 amps. asking this because i can’t increase the current. and it seems like white flat requires higher current. so before ordering new leds, just want to be sure.
well that’s a good news, i was reading a thread about black flat on Emisar D1s @ 5amp and manufacturer abandoned the plan so i thought maybe it requires higher current. one more thing, can i reflow it on xm-l2 board or not. and do i need to worry about anything else ? or its just replacing the led and go kinda thing.
