TK's Emisar D4V2 review
Good to see you can now adjust the thermal sensor to the correct ambient temperature.
My first D4 was spot on, but my other two showed 12-15 degrees above ambient.
I really like the upgrades to the ui and the light itself . Do i need another one? Absolutely - probably two!
need? want?
I think i need them so i cant afford copious amounts of alcohol. he he.
yo any good belt clip for the 18350 tube any coolones out there?
Well..
#include <mewantzshinyflashlight> //(basic library)
If (Emisar has Anduril){
me bought my firszt Emisar :p //(D4V2 that is.. )
The End..
hi everyone, I am going to purchase a emisar d4 v2 i just need some clarification and answers since i am a newbie
i just got my emisar d18 and it came with sst20 5k and i think its so pale for me since I am edcing a s1r baton ii
-which one should i opt sst20 6500k or xpl hi v3 1a 6500k ?
-also which one is better 18350 tube vs 18500 tube? does it have difference in runtime and output? and will i have to get another size battery? so if i would not want to use the normal tube that means i dont have to buy samsung 30q battery for the original tube right?
-also i emailed hank but hasnt got any reply yet. do they offer different shipping option(faster express shipping for a cost) as I got my d18 for almost a month and I want to order today so I can get it max 2 weeks since I am going overseas and i want to take it with me
thank you very much for everyones help. newbie here
regarding shipping, click on the shipping link on his website, you need to contact him for other available shipping options.
When you say pale, what do you mean exactly? Not often I come across someone who prefers 6500k :o
The SST20 will be a little “green” at at lower lumens, but should clean up at high. Maybe check out XPL HI 5000K - more of a straight “white” to me than most other emitters.
hi thanks for the reply. I can say pale comparing it to my olight s1r baton ii (not sure of the tint of it )
had always been in love with bluish tint of my lights including my motorcycle lights and car HID lights which was i think 10k tint.
Dear lord. Okay, yep, the Olight you have is 6500k, if you’re after that, then go for either SST20 or XPL HI in that temp.
thank you for your advice, i was just being dumb, when i was charging my olight i saw a writing on top that it says 70 cri 6500k. so my bad. :person_facepalming:
All good! These things happen :slight_smile:
Great way to keep the hobby alive. First go for cool white high output -> replace everything with neutral white -> get into cri and replace everything again -> go on a 4000k hcri quest -> repeat for 3000k.
Don’t ask how I know :person_facepalming:
Are you me ? :innocent:
He is we!
What a cool light, maybe one day I will get it.
Thanks to the team that made this happen.
Have to try the Anduril system. Ordered !
TK, then what’s the 7135x1 level? Is that ramping level 65?
Yes. Max 7135 on a 150 step ramp is level 65.
It depends on the specific light, but yes, on this one, the 1x7135 level is 65/150.
These levels are typically determined by a combination of measurement, math, intuitive feel, and rounding. So it’s different per light and I’d generally recommend looking up the details from the source code when in doubt. It typically has the exact numbers and the command or formula used to calculate the ramp.
