Goodbye C Drive
Although I don’t disagree, Win7 is very close to end of life/end of support. No more patches.
Right now I am trying to install Windows 7 because that's what the computer came with, and I still have the installation disc.
If that doesn't work, I'm in real trouble.
I haven't backed up to an external drive in a long time, but I should have used that backup.
I think I'll do that if I can get Windows 7 to install.
I'm aware of that, but that was not an option as Windows would not boot.
I really should have done that!
I like Windows 10 more than Windows 7.
But I liked Windows 7 more than Windows 8.
Windows 10 seems to be the fastest.
I thought that there was a Startup Repair option with the Win7 installation disk. But it’s been a long since I installed Win7 on a PC :frowning:
I now have a fresh copy of Windows 7!
I had Win10, and there is Startup Repair, but NONE of the options worked.
If you haven’t wiped it out yet, you should be able to get the data (based on the description). If you have a place to put the files, a USB stick, and another computer you can use a “Live” USB (something like Ubuntu as suggested above) to get access to the files and copy them to a safe place.
Anything important on there you need?
I’m happy to help walk you through some of that. This is what I do for a living (well… mostly servers and networks these days, but I do occasionally assist the “Desktop Support” guys)
yea you need to back up personal files before upgrading. Also your chrome bookmarks. Maybe registry files of your most used files say on Media Player Classic or bookmarks on pdf/comic reader etc… Also back-up your passwords stored on the PC etc…Windows sometimes does a nice upgrade and keeps old files, but when the updates or patches go back they do a “total refresh” and don’t save your files.
It wasn't the upgrade from Win7 to Win10 that caused the problem.
It was TweakBit Driver Updater.
I already wiped it out.
I do have a backup from last year that I will try to restore.
For the Chrome stuff, if you sign in with a Google account you can sync all the bookmarks/history/saved passwords/etc. Not a bad idea to get that going if you are friendly with Google.
You can use OneDrive or Google Drive to keep some of the more important stuff synced to the cloud in case you have any future issues.
I agree re: using third party software to update drivers… Windows Update on Windows 10 seems to grab the drivers for almost any device automatically, and I tend to use that for everything except maybe fancier graphics adapters or highly specialized hardware (things like Panoramic X-ray machines, old dot matrix printers, etc).
If your computer is a Dell/Lenovo/etc you can usually get their software to install and update the drivers. These are trustworthy, but I’ve had mixed results with nag screens and advertising on some of those.
Get your backups running automatically for the important stuff, and check them at least once in a while. For anything critical, I recommend the “3-2-1” strategy: 3 copies of the data, 2 different storage mediums (disk, cloud, DVD, tape, stone tablets, etc), 1 copy off-site.
Since you are on Windows, you can write a batch script to run a robocopy job on specific folders. you could even use the task scheduler to run this automatically. These tools are built into Windows and work well. TONS of info on the internet about how to get them working because they’ve been around for a long time. I could probably mock up a script to help you get started. It is pretty simple once you have a template.
Does not really matter. I have under maintenance a few machines running XP, working as it should.
Mike
Yep, there will most likely be hacks to extend the life of Win7 machines just like those that exist for WinXP machines.
I like to try out the different OS's and see which works best for me.
@raccoon city
What happend exactly when you tried to boot. When did it crash?
If the driver tool intalled inapropiate ahci drivers the system would not boot anymore. But you could have changed the option to use ahci in the bios. If this was the problem your system would have started again. And then you could have installed the correct driver again.
Would be helpfull to know more about the problem to help.
I don't know if the problem was with AHCI drivers.
It's too late to try to fix it as I formatted the C drive.
Next time, though.
NEVER UPDATE DRIVERS!
maybe 20 years ago it was a good idea to update drivers, but nowadays if you update drivers you WILL get more problems.
That is because software development, and especially driver development has reached an all time low. Everyone is now a programmer and incompetence has plagued this industry.
I’m still on Windows 7, and Yosemite on Mac and I will use them as long as I can do my job. Newer versions are terrible
I had a problem a few months ago with Windows 10 on my gaming PC. Intermittent crashes had become frequent and it had started crashing several times a day.
When I went to reinstall Windows, I noticed an option to reinstall without erasing my data. I used this and then reinstalled. The computer now works perfectly with no crashes.
The problem was the razor copperhead gaming mouse I’d been using. The latest available drivers were 10+ years old and were incompatible with Windows 10. Getting a newer gaming mouse with Windows 10 compatible drivers and installing that in conjunction with system reinstall fixed the problem.
I tried to do that, but that option did not work for me.
