[Review] Acebeam W30 LEP 21700 flashlight
127 posts / 0 new
Rusty Joe
Rusty Joe's picture
Last seen: 4 hours 52 min ago
jericho0o wrote:
Rusty Joe wrote:
jericho0o wrote:
Welp, got the 6500K shipping out for however long it’ll take HKEquipment to ship it. Good looks on that code SKV89 much appreciated.
Will post extremely sub-par pics soon as I get some play time with it (because I am no night-photo expert)
Once again, BLF is the bee’s knees
Yep! And you are going to have actually more throw than you can use with that thing! Seriously!
Actually the intended use would be to get Simon’s attention in China regarding my order status on AliExpress while never having to leave New Jersey Silly
Um, okay! Smile
cabfrank
Last seen: 22 hours 59 min ago
Is the same type of eye protection required for these as it is for lasers?
djozz
djozz's picture
Last seen: 2 min 39 sec ago
No, not at all. What comes out of the front is mostly not laserlight anymore, it is phosfor fluorescence plus a bit of the original blue laser light but dispersed so harmless. In fact it is no different than a weak 450 lumen aspheric light, just extremely nicely projected in a parallel beam.
Unless something breaks inside and the blue laserbeam comes out of alignment and escapes through the lens. But I assume that the construction is such that that does not happen easily.
cabfrank
Thanks djozz. I’m sure more of these will hit the market, and eventually the prices will come down. I will have to get one.
Firelight2
Firelight2's picture
Last seen: 49 min 47 sec ago
My understanding is the LEP module works like this:
  • blue laser diode projects laser beam forward.
  • laser beam passes through phosphor material. Phosphor scatters some of the blue light, plus emits red and green. Result is a very intense point source of white light. This white light is not coherent, so is much less dangerous than the original laser beam.
  • An aspheric lens captures this white light and focuses it out the front in exactly the same way that an aspheric lens LED light works.
  • A small portion of the original blue laser light passes through the phosphor layer as a coherent beam. To remove this from the output of the light a small rectangular mirror is mounted on the back center of the lens. This mirror diverts any remaining coherent blue light 90 degrees harmlessly into the side of the bezel.
Result is no special eye protection should be needed for the use of an intact LEP light. However, the W30 is still a 1.4 million lux light, so don’t point it at someone’s face. I suppose you could blind someone if they looked into the beam long enough just as you could with a 1.4 million lux LED light.
If things go out of alignment so the beam misses the mirror or the mirror falls off the back of the lens then there might be a danger.
cabfrank
Thanks. Definitely not something to mess around with or shine at people.
djozz
djozz's picture
No, the 1.4 million lux is only the number calculated back to 1 meter from measuring a collimated hotspot far away. But at a real 1 meter the beam is not yet collimated so you will never measure that 1.4 million lux there. The light is only just on its way from a fairly large surface, the lens, so yes it is blindingly bright but not really different from say a Brinyte B152 with dedomed XP-G2.
JoeH12.81
Last seen: 2 months 1 hour ago
It seems W30 CRI model on back order everywhere, same with 6500k as the initial stock has sold quickly. Joyce at HK equipment informed me ACEBeam has back ordered due to LEP modules not arriving as expected for assembly. She told me she’d post beam shots on BLF of the different tint models when stock arrives…hopefully soon. I plan to get the CRI edition, as I prefer the tint, but if the beamn intensity is inferior to the 6500k I’d opt that way. If there is anyone out there with CRI edition, please post some beam shots Smile cheers all!
SKV89
Last seen: 2 days 5 hours ago
Andrew & Amanda said the HI CRI should be back in stock in 3 weeks
CREEXHP70LED
CREEXHP70LED's picture
Last seen: 10 months 2 weeks ago
I don’t need one, but since I will most likely buy one anyway, I might as well order all three tints. LOL.
Also, I am 100% sure this light will never be offered with a crenelated bezel. The light will do much more damage.
djozz
djozz's picture
Or else use the red filter from the W30 on your camera for red pictures (talking about marginally useful Facepalm ).
cabfrank
I like the way you think.
SKV89
Thumbs Up Looking forward to tpur beam shots. Havent heard anyone mention anything about the 4000k version so it would be interesting to see Big Smile
I ordered the CRI one from Andrew and Amanda
Hardusvd70
Hardusvd70's picture
Last seen: 3 hours 17 min ago
Did compare the W30 6500K against my Astrolux MF04 6500K and BLF GT 6500K and results were as followed for 10 meter throw. .
1. W30 was 15720 lux.
2. MF04 was 13310 lux.
3. GT was 11800.
Results at switch on.
Must say the W30 is a really a great thrower for such small size.
Hardusvd70
SKV89
Hardusvd70, which W30 version did you get?
Also Vinh modded the W30 and got some crazy numbers
Lightbringer
Lightbringer's picture
Last seen: 1 hour 4 min ago
Not crazy, just irrational.
Lightbringer
Uhh, yeah, nobody’s gonna get that…
https://en.wikipedia.org/wiki/Irrational_number
AmericanDissent
He’s got some great numbers out of them. Sadly, when I sent mine in it would not accept any boost. It was the first time he couldn’t get any improvement over stock. Thankfully, mine tested at 1.8M cd in stock form, so I can’t be too disappointed… Or at least I shouldn’t be
SKV89
That’s not good to hear. I just received my HI CRI at first and it measures only 228 lumens at 1s w/ both stock Acebeam battery and Samsung 40T Crying Lumen output is the same w/ and w/o glass lens, which means the glass lens is very high quality.
Took some photometric measurements:
At beam center
CCT: 16255K
DUV: 0.0045
Ra (CRI): 85.7
R9: 36.9
Rf: 76
Rg: 89
At outer hotspot:
CCT: 2077K
DUV: -0.0099
Ra (CRI): 85.5
R9: 23.8
Rf: 78
Rg: 104
Will send it to Vinh. Hope he can boost it some.
JoeH12.81
Adhara, thank you for the feedback. I ended up placing an order with Vinh for a 6500k W30vn copy, awaiting receipt of goods, but sounds like I made the right choice. Atleast sheer output speaking. Been following the candlepower forum thread that AmericanDissent is talking about, so strange that copy wouldn’t boost, 1.8 is a tremendous output but I’m sure disappointing when expecting some increase. I know Vinh talked about inconsistent QC with alignment, but for it to not accept the mod at all is confounding. I’ll chime in when it arrives and let you guys know if the problem was isolated to that copy or not. Have a good one all!
dmsoule
Last seen: 4 days 7 hours ago
At beam center
CCT: 16255K
DUV: 0.0045
Ra (CRI): 85.7
R9: 36.9
Rf: 76
Rg: 89
At outer hotspot:
CCT: 2077K
DUV: -0.0099
Ra (CRI): 85.5
R9: 23.8
Rf: 78
Rg: 104
Is that CCT at beam center a misprint? 16255K? Or possibly I don’t understand how CCT is calculated. Also, does the beam look warm or neutral?
JoeH12.81
SKV89,
Does 228lumen seem low? I know vinh was talking about only getting 300-350 from 6500k. Both are well under the claimed output. How does the HCRI throw? Look good? Do you like it? Any beam shots?
JoeH12.81
300-350 stock, before boost. 500+ with boost.
SKV89
At beam center
CCT: 16255K
DUV: 0.0045
Ra (CRI): 85.7
R9: 36.9
Rf: 76
Rg: 89
At outer hotspot:
CCT: 2077K
DUV: -0.0099
Ra (CRI): 85.5
R9: 23.8
Rf: 78
Rg: 104
Not a typo. There is a huge tint shift within the hotspot. There is a ULTRA CW hole at the center. Highest point I measure was actually slightly over 20,000K but the point is very small.
I’m waiting for it to get dark to see how it throws.
Hardusvd70
Measured at 10 meter distance.
Hardusvd70
The_Driver
The_Driver's picture
Last seen: 11 hours 59 min ago
SKV89 wrote:
That's not good to hear. I just received my HI CRI at first and it measures only 228 lumens at 1s w/ both stock Acebeam battery and Samsung 40T Crying Lumen output is the same w/ and w/o glass lens, which means the glass lens is very high quality. Took some photometric measurements: At beam center CCT: 16255K DUV: 0.0045 Ra (CRI): 85.7 R9: 36.9 Rf: 76 Rg: 89 At outer hotspot: CCT: 2077K DUV: -0.0099 Ra (CRI): 85.5 R9: 23.8 Rf: 78 Rg: 104 Will send it to Vinh. Hope he can boost it some.
So you got the W30 high-cri, not the W10 high-cri? Do you think there is a difference between the two regarding the tint (some beamshots of the W10 were linked to a few weeks ago).
ZILZAL
This light is rated as diving light 100m but didn't see anyone testing it underwater.
Theodore41
Last seen: 2 weeks 6 days ago
Glenn7 wrote:
Well unless you use optics your not really going to see much detail at more than 300 meters with the naked eye, its more that the higher the lux the brighter things will be at say 300 meters and back.
To make it do say 2000lm I reckon it would be down to how much power they pump out of the laser as it is still only shining onto a phosphor surface – I think the W30 is at 12watts so you would need 48+ watts I’m thinking – so it might be a cross between how much power the laser can by law be sold at before it’s classed as a weapon (as it is in a lot of countries anything over .5 of a Watt) even though no UV comes out the front, As the laser light is bent by a prism onto the phosphor then sent through an aspheric lens I’m wondering if you put too much juice through the laser it might burn the phosphor? it would be nice and hot anyway, dunno.
Νο .5W,but exactly 5mW.
Anyway,I have a 5W blue laser pointer. Smile
Theodore41
electricjelly wrote:
JoeH12.81 wrote:
I know I dont need this, but damn I want one bad.
I felt this way about every expensive light I’ve bought. Lol
I’m feeling it again for this one. Trying hard to resist. Hi Cri availability might be the final straw.
I understand you so much… Big Smile
Theodore41
ZILZAL wrote:
This light is rated as diving light 100m but didn’t see anyone testing it underwater.
Look at the video. http://budgetlightforum.com/node/68322
