TK's Emisar D4 review
5356 posts / 0 new
Klayking
Klayking's picture
XP-L HI 3A, short tube, and I’ll call it the Noisy Cricket. Hand it to muggles in momentary full output mode and watch them get thrown backwards by the recoil.
firestorm
Last seen: 2 years 2 months ago
ToyKeeper wrote:
That looks like the old D4 clip, from before Hank found a better one.
yes.. i was one of the first ones to get the d4, sadly with the old clips as well.. hahahaha
blueb8llz
Last seen: 7 hours 15 min ago
My d4 xplhi seems to be only doing 2500 lumens with a 30q. Top of ramp and double clicking gives exact same output. Is there a setting I could have possibly changed where turbo is not 4000+ lumens.
thisnameisvalid
thisnameisvalid's picture
Last seen: 2 months 6 days ago
D4V2 or D4? The D4 uses a much simpler firmware and there’s no way to change the top of ramp brightness; it should be exactly the same as turbo. Is your battery fully charged? It will only put out 4000+ on a fully charged battery
mortuus
mortuus's picture
Last seen: 1 hour 18 min ago
how do u know its not putting out close to 4000 lumens, did u measure it or compared to lights in similar lumens range ? if battery fully charged idk.. can u try a different ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 3 weeks 4 days ago
Set your ramp ceiling to 21 clicks and try the light again.
blueb8llz
Silly mistake. Battery was not fully charged. But after putting a fully charged battery, I still only got 3000 lumens. I’m getting my numbers just based on a ceiling bounce using my new d4v2 as a reference.
If my new d4v2 sst20 is 4200 lumens I got 500 on my meter. And only 350 with the old d4.
Same cell.
This is at start up.
BurningPlayd0h
I’m pretty sure higher intensity/candela leads to higher reading with ceiling bounce readings. The SST-20 is throwier/higher candela.
SST-20 w/frosted optic vs XPL HI with clear would be a closer comparison.
pennzy
pennzy's picture
Last seen: 1 hour 25 min ago
Bought my D4 a year ago. Yesterday my pocket clip came out of my pocket in pieces . I don’t use the clip , but it broke just from lying on the couch, must of rolled over on it. Pretty delicate if that is all it takes. I would not rely on it for all that clip the D4 outside the pocket.
pennzy
pennzy's picture
Yeah. One of arms broke off.
pennzy
pennzy's picture
No, mine is the newer one. It went on super tight and would not even rotate in the groove.
bquinlan
Last seen: 2 weeks 5 days ago
Most of the snap-on clips I have tried on various lights have broken fairly quickly. I must be hard on them, but I do think they’re built too thin. That is why I now use ArmyTek Wizard clips on pretty much everything.
The ArmyTek clips are wider and thicker than any others I’ve tried. That means they do not fit into the grooves designed to hold a clip on anyone else’s lights. However, if you ignore that, they stay in place just fine. And I have not managed to break any of them so far.
firestorm
is it possible to transfer the internals of the D4V2 to the D4ti? if so how? im thinking about updating my d4 to the new UI. and i want the titanium body.
please make the titanium version for the D4V2..
Firelight2
Firelight2's picture
Last seen: 4 hours 42 min ago
… or you can just stick the D4V2 head on top of the D4V1’s titanium body and tailcap. You get worse thermal management without the copper head. But on the other hand the light is also a lot lighter than with the copper head.
It also makes for a surprisingly attractive looking light:
firestorm
!{width:70%}https://i.imgur.com/CzgPsQw.jpg!
yes but id like the copper heatsink also. just the internals. can anyone show us how to disassemble the d4?
HKSJOSHUA_
HKSJOSHUA_'s picture
Last seen: 10 months 3 weeks ago
Appreciate all the little things in life!
HKSJOSHUA_
Has anyone used these in a d4v2?
Noticed these are the newest 18350 cells out I believe, I purchased two for 6.fidy
sbslider
sbslider's picture
Last seen: 1 week 5 days ago
I’m running Vapcell 18350, 1100mAhr, works great in the V1 light. Looks like the same form factor as your cell in the picture above.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
HKSJOSHUA_
I may order two of those vapcells being 1100 mah thanks
OneBadWolf
My D4 V1 appears to be possessed. I carry it lens up in a holster, and the other day, I smelled something burning.
I took off my jacket, just in time to see my shirt starting to burn. There is a perfectly circular hole in it. I thought perhaps I forgot to 6 click it.
Today however, while changing, I noticed a white light coming from my pants, which I had laid on the bed, the light was on, and hot enough to be painful trying to remove it from the holster, to shut it off.
It wouldn’t shut off. I had to back off the tail cap. I set it on my desk, and when cool, screwed the tailcap back on.
It will randomly turn itself on, sometimes a full power flash, sometimes dim, it has even ramped up and down. I tried to check/reset the thermal management, but 10 clicks, it just stays off.
This is new behavior for it, I use Sony VTC6 batts in it for the year and a half I’ve had it, never a problem. If anybody has a fix, I’d appreciate it. It’s not practical to have to twist the tailcap on to use the light, but its no longer safe to carry. I’ve cleaned & inspected it regularly, Maybe those many drops have added up. Ideas?
lionheart_2281
lionheart_2281's picture
Last seen: 3 hours 43 min ago
I’m not a modder but I can certainly say without hesitation that I mechanically lock mine out whenever I carry in my pocket (after burning a hole in a pair of jeans)
ToyKeeper
ToyKeeper's picture
Last seen: 21 hours 29 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
OneBadWolf wrote:
My D4 V1 appears to be possessed. … This is new behavior … Ideas?
It’s pretty rare, but it seems that sometimes the D4 can end up with the switch wires shorted, which makes it think the button is being held when it’s not. I encountered this issue once on one of mine, and I fixed it be replacing a switch wire and being extra careful when putting the driver back in. Before that though, it would sometimes detect button presses when there were none.
Just to be sure, you have an original model with RampingIOS, right? (so 6 clicks for lockout, 8 clicks for beacon mode)
In more recent firmware, there is code to detect a stuck button and respond in a manner which is more safe. The original didn’t have that, though.
Would you be willing to run some tests, to help diagnose the issue?
Starkm32
Starkm32's picture
Last seen: 11 months 2 weeks ago
Curious if anyone has had a serious hot pants romance with an over eager
D4.
I need to know since I am looking for a couple of D4 (w/219C) to use as winter hand warmers
When riding my mountain bike.
Do you suppose Mountain would have some NOS in a dark shelf somewhere? Cool
Anyone want to get rid of their hot rod? For a bargain basement $ALE price?
hank
hank's picture
BurningPlayd0h
Hank (Wang, not the user above Big Smile ) bakes the discount right into his base prices. He doesn’t make people search for codes, sign up for special GBs, or rip off customers that don’t know about/haven’t found the right forum where a discount is posted.
Firelight2
Starkm32 wrote:
Curious if anyone has had a serious hot pants romance with an over eager D4.
Yup.
Last year, I lost a couple pants pockets to the original Emisar D4. Turned on in my pocket and burned a hole the size of the front of the light through the pocket. I didn’t feel any heat on my leg and the outer cloth on my pants wasn’t damaged… but the pocket was toast.
Fortunately, today’s Emisar D4v2 has 3 features to make it pocket-safe that were all missing in the original D4:
  • Max ramp can be manually set to a safe-for-pocket level. The original D4 used RampingIOS firmware. If the button accidentally depressed in your pocket and was held down the light would ramp up to turbo and stay there. In the D4v2 with Anduril, the same action only ramps the light to the top of the ramp which is below turbo (and can be manually set). The only way to get to turbo is to double-click when the light is on… an operation that is unlikely to happen by accident in the pocket. In my Anduril lights I like to set the max-ramp to just below where damage would occur to my pocket.
  • The latest versions of Anduril come with pocket-protection. If the button is pressed and held, the light will ramp up to max ramp, then pause, then ramp down to moonlight, turn off, and activate electronic lockout. My D4v2 Ti came with this updated Anduril version installed.
  • It is now possible to buy the D4v2 with an optional raised switchboot retaining ring. The raised ring keeps pocket cargo from hitting the button and greatly reduces the chances of accidental pocket activation.
Personally, I consider my Anduril lights to be completely pocket-safe. I haven’t had any problems and don’t feel the raised ring is even necessary.
Starkm32
Starkm32's picture
Thanks for your informative post.
I generally twist power off on my D4S, just to be over cautious. Blushing
I think a pocket friendly 18650 (with power twist off) OG D4, or two, would serve
As handlebar lights / hand warmers.
A dual purpose D4 for winter bike rides? Beer
RollerBoySE
RollerBoySE's picture
Firelight2 wrote:
Yup.
Since you already have tested it, which max level would you say is pocket safe?
Firelight2
I forget what mine is set at right now. I think I’ve set the max ramp at 30 or 35 steps below max turbo brightness.
BOO5TED
BOO5TED's picture
Last seen: 10 hours 42 min ago
I’ve looked through the thread but didn’t see anything and I’m sure it’s been asked already but will the stainless bezel from the D4V2 fit the original D4?
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
