First, I will say that RD Tech makes great products.
However, these sales threads are very confusing and I have never been able to actually get the price that is posted in these threads.
It is usually either limited or restricted (new users only) coupon availability or the deal has expired.
Why not just simply offer a discount code for BLF members?
Hi friend
thank you for your message and your support
I don’t know the detail, most sale promotion have time limit, when the time is end, you can’t get the discount, please tell me which products you need, I can offer you discount
Hi my dear BLF friend
Thank you for your long time support in BLF , I saw many many people like our products and also need better price , so in order to appreciate BLF friends help and stratify some friends wish, I decide to release coupons for some hot sale products, and each week will update new coupons, hope you can find some big surprise
new share
Product name: RD DPH5005 Buck-boost converter Constant Voltage current Programmable digital control Power Supply color LCD voltmeter 50V 5A
Product link: 43.0€ 23% OFF|RD DPH5005 Buck boost converter Konstante Spannung strom Programmierbare digital control Netzteil farbe LCD multimeter 50V 5A|lcd digital voltmeter|voltmeter 50vvoltmeter lcd - AliExpress
[This power supply is the best of available modular units. Packed in a box of foam. The module itself is additionally in a package of foam polyethylene. All the components of the seller carefully packed in separate bags of puffy film. The assembly of the unit is simple and understandable. The board is made of quality components, the components are soldered smoothly and do not cause complaints, the flux is well washed. Also there is a bluetooth adapter, to connect to a computer. The unit has an active cooling system of the radiator, which turns on at a current of 10 amps. The accuracy of the voltmeter readings is very high, the error is only about 0,02 volts. Very satisfied with the product, i recommend to buy. The seller very quickly sent the goods and deserved 5 stars.]
new share
Product name:RD UM24 UM24C APP USB 2.0 LCD Display Voltmeter ammeter battery charge voltage current meter multimeter cable measure Tester
Product link:
[I recommend the seller in 100% very fast shipping, reliably packed, very good contact with the seller, the highest quality goods as shown in the pictures. My rating is 5+ thanks to the seller. ]
new share
Product name:RD UM34 UM34C for APP USB 3.0 Type-C DC Voltmeter ammeter voltage current meter battery charge measure cable resistance Tester
Product link:https://www.aliexpress.com/item/32880908871.html
[’S Days to Germany, looks great and works well. I recommend]
new share:
RD TC66/TC66C Type-C voltmeter ammeter 2 way multimeter
[This tester i received on free for my first satisfied delivery reactive days 12 to ufa everything works fine. When delivered, the packaging was damaged but the tester itself did not suffer a reliable packaging. Sold well done 5 + to him.] https://www.aliexpress.com/item/32968303350.html
new share
RD AT35 5 digits voltmeter ammeter multimeter
[Fast shipping. Shipping 16 days. Track tracked. Packaging is reliable. The product is quality and corresponds to the description! I ’ve known this store for a long time. All products purchased from this seller work without fail! And this time everything is wonderful! Thank you very much to the seller! Product and seller recommend!] https://www.aliexpress.com/item/33022448123.html
New Share
RD AT34 USB 3.0 voltmeter ammeter multimeter
[Excellent tester, the description corresponds, the device is packed reliably, although in football play. everything works. delivery to rostov on don 14 days. the seller thanks and good luck in business! i recommend of course) ] https://www.aliexpress.com/item/32897200670.html
new share
RD DPS5015 DC Step-down Power Supply
[Order received, everything is fine, came quickly and securely packed. The module works as expected. Excellent product, reliable supplier. Thank you.] https://www.aliexpress.com/item/32702714880.html
new share
RD DPS5005 DC Step-down Power Supply
[Good set, a little soldering. It is a pity that there was no connector for connecting the cooler, i had to cut off the wire. Complete wires are enough to collect all together. The first inclusion was smoke test.]
dont forget this is the second day of big discount
here is the article of the big discount:
NEW SHARE
RD 100v/20A 7in1 OLED Multifunction Tester
[ It’s a good thing superski packed. For what thanks to the seller.Everything works. Error not more than 5%] https://www.aliexpress.com/item/32788030454.html
NEW SHARE
RD 33v10A 7in1 OLED Multifunction Tester
[Delivery to the motherland of lenin 14 days. Packaging worthy (foam, pupyrka, scotch). Starts working from about 3,7 v. Measures, for its cost, exactly. Of the minuses: small numbers on the display. In my opinion, you can add switching screens with each parameter built-in button on the ring, but with a large font. The work of the seller and the goods was satisfied] https://www.aliexpress.com/item/32570250500.html
I am so sorry, but we post this review is for posting our review, only on this post, we did not put that at other place ,
this is a special post
