Same issue here, delayed to 12 th july…
Late comer, here.
Where do I go to surrender my wallet?
This is endless.
Got notification of one of the 2 I ordered was not in stock. Chose to wait also.
Shipping has started for cool white orders.
Interested.
My 5700k allegedly shipped today. (i also received the “out of stock” email like 2 days ago and choose the “wait” option)
Mine shipped, it said it was backordered a couple of days ago also. I’ve been sticking with the wait option and so far all of my back orders have worked out within about a week or less.
Sweet!
Mine has shipped finally.
Freeme can you please send me a code i want a XHP50.2 FT03
I put a XHP50.2 into my FT03 its so much fun i got 4200 startup lumens and it sat at like 3950 for a bit it does heat up heaps quick. My lux reading was 174kcd that was teken from an average of 3 test at 5m and my LED isn’t even centered that great. Slice the dome you will be laughing!
Such a fun light.Ill return this one to my stock SST40 with the sliced dome cause that has its place also.
Was it difficult to slice the dome? How much throw do you get after slicing? I want to slice mine but I’m afraid I’ll destroy the led lol
Does this come with a 21700 to 26650 converter?
People said no earlier. It only comes with an 18650 sleeve. You typically don’t need a sleeve with a 21700. If you do need one it’s easy to use a piece of cardboard.
dont use 21700 cells… they are too long and will compress too much on springs… atleast on 2 different batteries it doesnt matter i tryied, u are not supposed to use much force to screw down a tailcap…
Thanks for the tip, I’ll stick with my Keeppower IMR 6000’s.
Freeme, Can you send me a code please? Thanks!
me too!
everydaysurvivalgear:Freeme can you please send me a code i want a XHP50.2 FT03
Sorry mate just seen this now. Dome slicing on flip chips LEDs is okay because you don’t have to worry about bonding wires. The LED inside my FT03 is not dedomend because i only bought 4 and have sliced 2 others already. Ill try and put a sliced XHP50.2 in there and see how it goes. The stock MCPCB is wide its 26mm i think so you can fit a washer around the LED easily enough and use that as guide for a straight cut. I’m not sure how low you can go but i used a 1mm thick washer and i went lower than that after.
California_Prepper: everydaysurvivalgear:Freeme can you please send me a code i want a XHP50.2 FT03
I ordered the xhp50.2 version as well. Now I’m trying to decide which one to dedome.
everydaysurvivalgear: California_Prepper: everydaysurvivalgear:Freeme can you please send me a code i want a XHP50.2 FT03
My SST40 FT03 is dedomend i love it the FT03 throws awesome with it. If you slice the XHP50.2 you will definitely gain lux it will push it over 200kcd but do you want a beam that throwy? The stock FT03 with the XHP50.2 already throws so good. Out does my L6 and S70 by a large margin.
On another note Its good to see more preppers on here.
