Bit of a clickbait title considering the #1 factor for healthy charge speed is the battery, not the charger. i canât imagine 4A being good for a 2000mAh cell
Looks like a nice charger though.
That looks like an Xtar Over Four slim.
Without the mains adapter and USB out ports.
4100mA Charge current and 2000mAh battery does not mean it charges in 30 minutes
at the end of charge the battery gets charged in CV with current going down slowly until termination
you may get 80-90% but not full
It is even faster, Fully Charged in 10 Minutes if you put a 700mAh Crapfire in there.
Is it unintentional coincidence that this charger is being presented on Independence Day? :-D
ROFLMAO!!
I really like seeing flashlights and chargers adopt USB-C. I hope the trend speeds up and we see more devices soon.
Is that smoke I see in the first photo?
OMG!!! :O See that smoke venting out of the battery terminals? }) They probably fried some rewrapped Doolidoodaaa cells with 4.1 amps. :-D
OTOH, maybe they just wanted to advertise this charger to heavy vapers and white smoke just looked like the right thing... 8^)
Did anyone bother to notify Tesla about this?
Perhaps they can make some improvements to it and have it fully re-charge the car in 15 minutes?
Tesla model 3âs, when using a super charger or other 250kW charging station already charge at the rediculous rate of 15 miles of range gained back per minute.
10 min of charging will drive you 150 miles!
Charging speed is not determined by output amps but C rating, so this is technically false advertising. Even more so considering the math behind 30 minutes completely skips the CV phase.
and for 100 Testlas charging at the same time you need to build a new medium-sized coal power plant
electrical cars are with todayâs battery technology an economical and ecological disaster
In some countries without heavy regulations the power companies will always go for the cheapest way to generate the electricity, along with the waste created by lithium cell production theyâre probably not so much greener after all. At least for the time being.
My country gets the power from hydro and on dry seasons there are regulations for turning off the central AC and large luminous signs for small and large business for hours each day. I canât imagine how would that work if we add a considerable amount of electric cars each capable of drawing the same power as several households. Electric cars are imported 100% tax free and there are already more charging stations than Teslas cars in the city thanks to corporations trying to look âgreenâ. I suppose it wonât take long until the government steps in and add even more free charging stations.
People tend to view electric power as unlimited and sustainable, and everything that looks Smokey bad and harmful, including steam. The media sold it well I guess.
@ will34:
And to think of the infrastructures thatâll have to be beefed up.
There is a push to build with renewables, and that is applaudable. The transport and substations, the delivery of 3 phase 550 / 600 (440 / 480 US) volt to new locations as parking areas and residentials, that will be an undertaking. The grids are built for the present demands; these will need to increase exponentially.
Say hello to brownoutsâŠ
The Built-in high-precision MCU ensure that the cut-off voltage is always within safe limits to extend the lifespan of the batteries
And to extend the lifespan of the batteries, charging a 2Ah cell with 4.1A current is probably not such a great idea.
The marketing leaves questions:
4,100 mA in two slots - would that be 2.1 A per slot?
Claim of fast charging a 2000 mAh battery in 30 minutes but (fuzzy) pictured 2600mAh cell*.
Second photo of a 4200mAh cell (presumably a 21700) not in charger with display results - â100%â states nothing of charge rate (canât make out the rest of LCD).
Xtar makes some good chargers, re-think your marketing.
According to specs on their website, it can do 2*4.1A.
Theyâre probably assuming the cell isnât fully depleted to begin with, but maybe at some 30% at the start of charging? But without stating it as such, yeah, thatâs some shady advertising. Iâd expect better from XTAR.
High current also mean increases the battery internal temperature which can probably operating beyond the battery specification charge current. Iâve read that âheatingâ the battery too hard could potential have done some damage to battery and life cycle.
High current cell arenât that cheap and you donât definitly want something tearing off your battery.
That the first case, 2nd is when the charger charge li ion cell beyond 4.20v threshold and stay there for pro long time also one of the reason of why internal batteryâs temperature to rise much higher than specs and worst of all, likely to harm battery life cycle.
Iâve also been seen that 3amps charge can push cell temperature up to 40 celcius which is still ok but for me pretty darn high. Now we have 4amp, wonder how that will look likeâŠ
