Mine shipped, it said it was backordered a couple of days ago also. I’ve been sticking with the wait option and so far all of my back orders have worked out within about a week or less.
People said no earlier. It only comes with an 18650 sleeve. You typically don’t need a sleeve with a 21700. If you do need one it’s easy to use a piece of cardboard.
dont use 21700 cells… they are too long and will compress too much on springs… atleast on 2 different batteries it doesnt matter i tryied, u are not supposed to use much force to screw down a tailcap…
Sorry mate just seen this now. Dome slicing on flip chips LEDs is okay because you don’t have to worry about bonding wires. The LED inside my FT03 is not dedomend because i only bought 4 and have sliced 2 others already. Ill try and put a sliced XHP50.2 in there and see how it goes. The stock MCPCB is wide its 26mm i think so you can fit a washer around the LED easily enough and use that as guide for a straight cut. I’m not sure how low you can go but i used a 1mm thick washer and i went lower than that after.
My SST40 FT03 is dedomend i love it the FT03 throws awesome with it. If you slice the XHP50.2 you will definitely gain lux it will push it over 200kcd but do you want a beam that throwy? The stock FT03 with the XHP50.2 already throws so good. Out does my L6 and S70 by a large margin.
On another note Its good to see more preppers on here.
I ordered today the XHP-50.2, anyone knows the exact BIN and ANSI white tint of the 5700k led used? (I would love if it was 2A tint)
Now I have 2 FT-03’s the neutral SST-40 and the 5700k Cree. Not sure which one I will like the most, anyone knows if the issues with the wood grain texture of the copper MCPCB has been solved for this model? Some SST-40’s had that issue (I had to polish the MCPCB on that one)
